Hi. May i know is it possible to rename the default iCloud folder name “Cryptomator”, to another name? Thank you.
Not to my knowledge. The iCloud folder “Cryptomator” is not a regular folder but an iCloud container that is identified by an application. If you look closely, the path is called ~/Library/Mobile\ Documents/iCloud~com~setolabs~Cryptomator/Documents
. I don’t think there is a way to rename that without breaking it.
Noted, thanks for the feedback.
