Firstly, I have been testing 1.5.0 beta 2, and I am currently setting up a large video library vault and it works great so thank you for that. Can you please tell me:
When do you expect the full release to be out?
Will the linux full release have an unlock vault on start option?
Will the linux full release have a start cryptomator on login option?
Will the linux full release have a working system tray icon that cryptomator minimises to? Ubuntu 16.04, Gnome 3.28.2. KStatusNotifierItem/AppIndicator Support did not fix this for me.
Will the vault format change again, or will any vault created with the second Beta need to be converted?
If using a vault stored in cloud - not synced - but browsable in Nautilus with google-drive-ocamlfuse, if conversion is necessary, will the whole vault have to be downloaded and changed, or just some of the files? I know most people will be using Cryptomator on vaults that are synced locally, but for a setup as I have described, if an entire several hundred GB vault has to be downloaded by google-drive-ocamlfuse to change the format, this could take a long time and if there was an issue with the connection or a crash - perhaps there is a good way to mitigate this, perhaps making a backup of the vault on the google drive web client.
