Hello everyone,
I use the lates version on a Macbook pro, latest operating system, without macfuse.
If I want to close an open container, the cryptomator hangs up.
If I close the cryptomator via the menu bar, I cannot restart it. It appears in the task manager, but neither on the desktop nor in the menu bar.
If I try to log out, nothing happens. After repeated loggin out in the menu bar I am able to login again. But restarting the cryptomator results in the following error message:
It is not possible to save the log file, because the system hangs up and needs to be restarted. Then the same problem closing containers starts from beginning.
Now I ask for support and what I can do.
Thank you very much, greetings!
