Hi, I’m not able to open PowerPoint files inside a Cryptomator Vault.
The same file moved for a normal folder works fine.
I am just having this problem with Powerpoint. Word and Excell files are working normally.
I’m using Windows 10 with Cryptomator 1.4.13.
Anyone else with this problem?
Yes! I have that problem too.
Just tested it.
No Problems with Cryptomator 1.5.3.
Your Version 1.4.13 is from August 2019. You should consider an update.
If you are using Dokany, please check this installed version also and if not latest (1.3.1.1000), then I recommend an update too.
I have no problems too.
Last version of Cryptomator 1.5.3 and last version of MS PowerPoint.
