I have a problem opening my safe, when I type the password it presents me this error instantly:
at org.cryptomator.common.vaults.FuseVolume.mount(FuseVolume.java:53)
at org.cryptomator.common.vaults.FuseVolume.mount(FuseVolume.java:42)
at org.cryptomator.common.vaults.Vault.unlock(Vault.java:132)
at org.cryptomator.frontend.fuse.mount.MacMounter.mount(MacMounter.java:48)
at org.cryptomator.frontend.fuse.mount.Mounter.mount(Mounter.java:8)
at org.cryptomator.common.vaults.FuseVolume.mount(FuseVolume.java:51)
... 12 more
at org.cryptomator.frontend.fuse.mount.MacMounter.mount(MacMounter.java:46)
... 14 more
... 15 more
Someone can help me? I have very important documents in this vault
