I have a problem with multiple vaults. All waults I have from previously version.
After I installed new version 1.5, I have empty vaults.
I added one vault, and one vault works OK.
When I tried to add second from my vaults (all vaults are migrated to 1.5), I not working. Nothing happens (after I drag´n´drop “masterkey.cryptomator” file).
When I tried to add second vault by click to “add vault” (“Pridat trezor” in my lang), I go to “open exist vault”, I search “masterkey.cryptomator” file, and after I add it, nothing happends.
yes, new vault is possible to create to empty Cryptomator.
When I tried create second new, It will be also created correct (on Google Drive), but not add to Cryptomator left menu.
The probably reason is, that Cryptomator try to add vault with previous name => first created vault has name “testnew” and second created has name “testnew2”. It can be seen in screen.
I look to LOG and see difference between adding first and second vault:
After add first vault is:
05:59:58.518 [App Background Thread 005] INFO o.c.u.a.CreateNewVaultPasswordController - Created vault at H:\*PATH*\testnew
05:59:59.535 [App Scheduled Executor 01] DEBUG o.c.common.settings.SettingsProvider - Attempting to save settings to C:\Users\*SOMEUSER*\AppData\Roaming\Cryptomator\settings.json
05:59:59.536 [App Scheduled Executor 01] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\*SOMEUSER*\AppData\Roaming\Cryptomator\settings.json
After add second vault is only:
06:02:14.351 [App Background Thread 005] INFO o.c.u.a.CreateNewVaultPasswordController - Created vault at H:\*PATH*\testnew2
Same problem here, Windows 10 Pro 1909 build 18363.778, Cryptomator 1.5.0, Dokany.
I’m using Drive File Stream and I can’t see more than one vault in Cryptomator, although it gets created.
Same problem here, Windows 10 Pro 1909 Tradition Chinese edition build 18363.778, Cryptomator 1.5.1, Dokany.
I’m using Google File Stream and I can’t add more than one vault or open second existing vault in the same drive.
But I can add second vault or open existing more than one vault in the same microsoft one drive.
