I just setup elementary os 5.0 Juno on top I installed cryptomator using apt-get install cryptomator.
When I start the window from cryptomator starts up and directly a popup saying something about update-check, but this popup window is not completely visible, and I can do nothing on the app.
Following the logfile the version of cryptomator is 1.4.6.
Following is a screenshot from the app:
and the contents of the logfile:
16:28:08.072 [main] INFO org.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.4.6 on Linux 4.15.0-47-generic (amd64)
16:28:08.189 [main] INFO o.c.launcher.IpcProtocolImpl - Received launch args:
16:28:08.408 [JavaFX Application Thread] INFO org.cryptomator.launcher.Cryptomator - JavaFX application started.
16:28:08.650 [JavaFX Application Thread] INFO o.c.ui.controllers.MainController - Unable to setPreferencesHandler, probably not supported on this OS.
16:28:32.852 [Thread-0] INFO o.c.launcher.CleanShutdownPerformer - Goodbye.
And the output from the app, when I start in terminal:
cryptomator
16:47:00.377 [main] DEBUG org.cryptomator.common.Environment - user.language: de
16:47:00.381 [main] DEBUG org.cryptomator.common.Environment - user.region: null
16:47:00.381 [main] DEBUG org.cryptomator.common.Environment - logback.configurationFile: null
16:47:00.381 [main] DEBUG org.cryptomator.common.Environment - cryptomator.settingsPath: ~/.config/Cryptomator/settings.json:~/.Cryptomator/settings.json
16:47:00.381 [main] DEBUG org.cryptomator.common.Environment - cryptomator.ipcPortPath: ~/.config/Cryptomator/ipcPort.bin:~/.Cryptomator/ipcPort.bin
16:47:00.381 [main] DEBUG org.cryptomator.common.Environment - cryptomator.keychainPath: null
16:47:00.381 [main] DEBUG org.cryptomator.common.Environment - cryptomator.logDir: ~/.local/share/Cryptomator/logs
16:47:00.381 [main] DEBUG org.cryptomator.common.Environment - cryptomator.mountPointsDir: ~/.local/share/Cryptomator/mnt
16:47:00.552 [main] DEBUG org.cryptomator.common.settings.SettingsProvider - Attempting to load settings from /home/carlo/.config/Cryptomator/settings.json
16:47:00.557 [main] DEBUG org.cryptomator.common.settings.SettingsProvider - Attempting to load settings from /home/carlo/.Cryptomator/settings.json
16:47:00.889 [main] INFO org.cryptomator.launcher.FileOpenRequestHandler - Unable to setOpenFileHandler, probably not supported on this OS.
16:47:00.913 [main] INFO org.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.4.6 on Linux 4.15.0-47-generic (amd64)
16:47:01.030 [main] INFO o.c.launcher.IpcProtocolImpl - Received launch args:
16:47:01.252 [JavaFX Application Thread] INFO org.cryptomator.launcher.Cryptomator - JavaFX application started.
16:47:01.495 [JavaFX Application Thread] INFO o.c.ui.controllers.MainController - Unable to setPreferencesHandler, probably not supported on this OS.
^C16:48:45.204 [Thread-0] INFO o.c.launcher.CleanShutdownPerformer - Goodbye.
Iām new to cryptomator, use it since two weeks on windows and android.
Would be great, if someone could help me with this problem
thanks in advance
Carlo
