Good night friends, how are you?
I write because I am having a huge problem.
I had my encrypted vault with a bunch of important files, which was synced to my Google Drive. Likewise, I have saved the recovery key with all the words.
The problem is that my disk broke, so when I reinstall my operating system on a new disk and try to lift my vault from the files I had in Google Drive, the application informs me that the vault has to be updated to a new format before i can access it.
And it asks me for the password to do the migration.
The problem is that it’s been a long time and I forgot the password, and I can’t find it anywhere.
I have some way with the recovery phrase or the files saved in Google Drive to recover, or reset the password to access the vault. Or I don’t know if it is possible to downgrade to a previous version to enter it.
I ask if you can please give me a hand with this, since I have a lot of very critical files inside the vault and I want to die from having lost access!
Vault Version 7 was App version 1.5.x.
If you install the latest 1.5.x version of Cryptomator, you should be able to change/reset your password without having to migrate tha vault.
After that I recommend to upgrade the app to the latest version and do the migration of the vault format.
Hello brother, thank you very much for your answer!
Could you tell me where I can download version 1.5.x of Cryptomator without having viruses?
I’m afraid to download it from anywhere.
