Does anyone combine Cryptomator with something else to achieve a cloud based note taking experience akin to Evernote? Any pros and cons, or best practices worth sharing?
Otherwise, any recommendations for cloud-based note taking apps with built-in encryption?
I’m using Joplin with E2EE enabled.
I’m a long term user of Google keep, and Apple notes (not heavy user because of the privacy issues I was concerned of).
Due to your recommendation I gave Joplin a try, and it seems I will stay.
Thank you for the hint. It’s perfect for me. Not as comfortable on mobile devices as the other both apps, but that’s ok for my purposes.
Thank you for the recommendation. I finally tried Joplin this week, and so far so good.
