Hi
Maybe this is old question…and if so apologies sent in advance.
I plan a factory reset of my android phone.
What should I do in order to keep my files that are encrypted on my sd-card?
Thanks crypto friends
Hi. encrypted files are just files. So if you are afraid that the files might be wiped during a factory reset, just remove the sd card.
