Any photographers here?
I purchased the Onedrive subscription and I also bought the Cryptomator app from Play Store.
So my questions are:
Question1
Do you create:
1 vault for ‘Photography’ as a whole, or
Recommend making 2 vaults, 1 for ‘Work’ stuff and 1 for ‘Personal’ stuff, or
1 vault for each project?
Question2
I can’t view thumbnails in the Cryptomator app for Android. Any workaround for it? Or some magic workflow?
Note: My exports are in .JPG and my raws are in .ARW (Sony mirrorless camera) formats.
Question3
Onedrive sadly does not have .ARW viewer on both its web browser and desktop app. Even though my pc is able to view .ARW format thumbnails when the files are on normal local storage, but when they are on the Onedrive folder, with ‘Always Available’ enabled, it is not shown. So I use Adobe Bridge to generate the thumbnails of raws stored on my Onedrive folder. But if this folder is actually encrypted, how do I generate thumbnails now?
