I’ve set up a pcloud vault after the latest Cryptomator update. For the most part everything is working fine, except when I try to move a folder from another directory in the files app. This works flawlessly with other vaults and partially copies the folder to the pcloud vault. It then throws out the following message: The Operation Can’t Be Completed. Couldn’t communicate with a helper application.
I haven’t seen this before and it occurs on both iOS and iPadOS, but only with the pcloud vault. Do I need the pcloud app installed?
Thank you for letting us know! I must admit though that I couldn’t quite follow everything and wasn’t able to reproduce this since I didn’t know the details. Would you be willing to write a bug report? Issues · cryptomator/ios · GitHub
Sorry for not reporting this correctly. Cryptomator 2.2.0 (882) and iOS 15.4. I actually think this may be in relation to pCloud having some trouble yesterday. I saw reports about the service having intermittent issues causing connection issues so perhaps that’s the issue? It seems to be working ok right now…
I do agree thought that moving folders is a bit buggy and the issue you shared is very like what I was trying (poorly) to describe.
