For me it works only if I open the vault with the same computer on which it was created. When I try to open it from another computer, OpenOffice documents are not opened. another user advised me to use Cryptomator 1.4 Beta, unfortunately I could not install it on Linux Mint. Therefore, i has ceased to use crytptomator. A pity, the idea is good. But only worth it if you do not waste hours to get that Sistem to work. In the moment, I would not recommend it.
A post was merged into an existing topic: OpenOffice Datein lassen sich nicht auf anderem Rechner öffnen
