I downloaded the win desktop app and tried to connect to an existing folder. After selecting the keyfile nothing happens but the same desktop windows is shown without adding my folder.
The same is valid if I create a new encrypted folder. The log file says:
16:53:06.430 [main] INFO org.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.3.4 on Windows 10 10.0 (amd64)
16:53:07.035 [JavaFX Application Thread] INFO o.c.launcher.MainApplication - JavaFX application started.
16:53:07.084 [JavaFX Application Thread] INFO o.c.common.settings.SettingsProvider - Failed to load settings, creating new one.
16:53:07.490 [JavaFX Application Thread] INFO org.cryptomator.jni.JniModule - loaded WinFunctions.dll
16:53:07.812 [pool-4-thread-1] INFO o.a.htp.impl.execchain.RetryExec - I/O exception (java.net.SocketException) caught when processing request to {s}->https://api.cryptomator.org:443: Permission denied: connect
16:53:07.813 [pool-4-thread-1] INFO o.a.http.impl.execchain.RetryExec - Retrying request to {s}->https://api.cryptomator.org:443
16:53:08.720 [JavaFX Application Thread] ERROR o.c.ui.util.AsyncTaskService - Uncaught exception
java.net.SocketException: Permission denied: connect
at java.net.DualStackPlainSocketImpl.waitForConnect(Native Method)
at java.net.DualStackPlainSocketImpl.socketConnect(DualStackPlainSocketImpl.java:85)
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
at java.net.Socket.connect(Socket.java:589)
at org.apache.http.conn.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:339)
at org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:142)
at org.apache.http.impl.conn.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:359)
at org.apache.http.impl.execchain.MainClientExec.establishRoute(MainClientExec.java:381)
at org.apache.http.impl.execchain.MainClientExec.execute(MainClientExec.java:237)
at org.apache.http.impl.execchain.ProtocolExec.execute(ProtocolExec.java:185)
at org.apache.http.impl.execchain.RetryExec.execute(RetryExec.java:89)
at org.apache.http.impl.execchain.RedirectExec.execute(RedirectExec.java:111)
at org.apache.http.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:185)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:83)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:108)
at org.cryptomator.ui.controllers.WelcomeController.lambda$checkForUpdates$0(WelcomeController.java:130)
16:53:42.941 [JavaFX Application Thread] INFO org.eclipse.jetty.util.log - Logging initialized @-1ms to org.eclipse.jetty.util.log.Slf4jLog
16:53:42.967 [JavaFX Application Thread] INFO o.c.frontend.webdav.WebDavServer - Binding server socket to 127.0.0.1:42427
16:54:17.593 [JavaFX Application Thread] INFO o.c.frontend.webdav.WebDavServer - Binding server socket to 127.0.0.1:42427
16:54:38.899 [JavaFX Application Thread] INFO o.c.frontend.webdav.WebDavServer - Binding server socket to 127.0.0.1:42427
16:54:41.604 [JavaFX Application Thread] INFO o.c.launcher.MainApplication - JavaFX application stopped.
16:54:41.607 [Thread-1] INFO o.c.launcher.CleanShutdownPerformer - Goodbye.
Any hints? I double checked my firewalls and all is set right there. Saying this, tthe port 443 is connected in my fritzbox to an external ip address which is linked to my NAS. Maybe this is the problem - any workaround for that?
