Hi All - I jsut started to use onedrive last week and found Crypotomator solution for confidentials files security.
I’am using cryptomator version 1.3.1 on windows 8 (64bits); I uploaded 41Go of files on onedrive from my computer A; then I installed Cryptomator on my second computer and I try to access files. I have access but I can see only 300Mb of files. I don’t understand where is the problem. if you encountered same problem, pls advice. many thanks in advanced for your help and I am sorry for my poor english. Lokes
Please ignore this post, the problem is solved. thanks
