If Custom Mount Flags are enabled and as a flag -oallow_root is passed, the app isn’t able to unlock the vault.
Same with -oallow_other.
Without custom flags all works.
I’d upload logs, but system won’t allow new users… so find a relevant stack below.
08:44:03.093 [JavaFX Application Thread] ERROR o.c.ui.unlock.UnlockWorkflow - Unlock failed for technical reasons.
at org.cryptomator.common.vaults.FuseVolume.mount(FuseVolume.java:54)
Caused by: org.cryptomator.frontend.fuse.mount.FuseMountException: ru.serce.jnrfuse.FuseException: Unable to mount FS
at org.cryptomator.frontend.fuse.mount.AbstractMounter.mount(AbstractMounter.java:46)
at org.cryptomator.frontend.fuse.mount.Mounter.mount(Mounter.java:15)
... 12 common frames omitted
at org.cryptomator.frontend.fuse.mount.AbstractMounter.lambda$mount$0(AbstractMounter.java:26)
... 1 common frames omitted
... 2 common frames omitted
