Hello everyone
I have tried Cryptomator on and off with Nextcloud in the past, hosted and self-hosted, but never committed to it because I read about stability issues due to the use webdav and the flakiness of both Apples’s and Nextcloud’s implementations .
Are these still an issue nowadays or does Cryptomator work reliably with Nextcloud?
Regards,
-Patrick
Kind of funny to ask this right now. Last week I stepped away from my self hosted nextcloud and moved everything to OneDrive.
Reason: I am not sure if the problem was the cheap, low resources server I used for hosting, or the quality of the iOS app or the windows client.
But for me there was always a problem to solve. Either the windows sync was not syncing, or the iOS app not responding or I realised I had do to an update of either the app or the client or the server to get everything running again. And the frequency of needed updates was just too high for me. I don’t want to invest the time needed for maintaining Nextcloud.
But: when the nextcloud environment was running smoothly, I also never had issues with my Cryptomator vaults on it.
Would I recommend nextcloud together with Cryptomator? If you have a strong virtual machine and having fun maintaining it on a regular basis: yes.
If you don’t, then it’s not worth the hassle.
Cryptomator Dev here ![]()
While I’m not a Nextcloud hosting expert, I can at least assure you that our team will be among the first people to notice if there is a problem or an incompatibility with any new version, because we’re using Nextcloud ourselves. ![]()
@overheadhunter that’s good to know, thank you!
So I have a couple of “free” 8Gb accounts in Nextcloud (.tab.digital) which I use for notes, reminders, bits and pieces that I need to edit at a later date, or just to store them (in a Cryptomator vault) a while before editing. I have had no problem with Nextcloud stability so far if that helps, although I appreciate not huge amounts of data going backwards and forwards.
