Deploy Backup and Sync in your organization to synchronize local files to Drive on the web, making them available on all your devices. Backup and Sync is the latest Drive sync client. The earlier version, Google Drive for Mac/PC, will no longer be supported as of December 11, 2017.
If that is the case, the annoying way of storing 2 copies of files on the computer will no longer be necessary. Could Cryptomator encrypt files for Google’s “Backup and Sync” solution or their new “Drive File System” without storing encrypted copies, but just decrypt the files when they are downloaded back?
What I am trying to accomplish is use Google Drive service (not software, the google drive software will become extinct on December 11) to backup my entire Disk D for example, it would be possible to do with both googles services “backup and sync” as well as “drive file system” however, Cryptomator seems to be tuned to google drive, how would Cryptomator handle encrypting the entire drive before its backed up to “Backup and Sync,” without storing an encrypted duplicate of each file
https://support.google.com/a/answer/7491144?hl=en&ref_topic=7455083
