YN03
November 9, 2020, 8:04pm
#1
Is possible to move or copy files/folders on android local vault (vault locked) ?
If I try files on android explorer to cryptomator, cryptamor need to unlock vault.
I try to create automatic backup my android files with cryptamor and FolderSync on my android phone. I think is not possible because locked/unlocked is a security mecanism ?
Many thanks.
Yannick
Hey and welcome to the community !
It is a security mechanism but you can set automatic-locking to Never
as wells as disable the setting automatic-locking When screen is disabled
in the Cryptomator for Android settings, see https://docs.cryptomator.org/en/latest/android/settings/#automatic-locking
YN03
November 10, 2020, 11:38am
#3
Okay, but on android I don’t acces on my vault with my files Explorer. I think is not possible ?
Yes, it is not yet possible to access the content of the vault using a file explorer but it will be as soon as Allow vault access by other apps through Document Provider is implemented.
YN03
November 10, 2020, 12:22pm
#5
Thank you for you reply fast
Thank you for your anwser, I asked myself the same question.
Do you know if this feature is under development ?
Thank you to the community and developers for their great work. !
JM
We’re currently working on open sourcing the Android app but this will be one of the next big features.
