Has anyone been able to mount a cryptomator vault directly on their Synology NAS using the docker image and without WebDAV? I got it working with WebDAV but the required caching on whichever server mounts the WebDAV endpoint is not ideal. I’m trying to figure out if I can mount my vault on the NAS so I can then install whichever services that need access to the unlocked vault locally.
Thank you!
