Good day!
I have been experiencing the following issue for some time now and after a bit of research and troubleshooting I was redirected here from trying to open a GitHub Issue.
PROBLEM
Unlocking a vault will almost always fail the first time with the error message below
Cryptomator Error Message
at org.cryptomator.common.vaults.DokanyVolume.mount(DokanyVolume.java:57)
Caused by: org.cryptomator.frontend.dokany.MountFailedException: java.lang.IllegalStateException: Mount failed: Driver answer that something is wrong.
at org.cryptomator.frontend.dokany.MountFactory.mount(MountFactory.java:128)
at org.cryptomator.common.vaults.DokanyVolume.mount(DokanyVolume.java:52)
... 11 more
Caused by: java.lang.IllegalStateException: Mount failed: Driver answer that something is wrong.
at com.dokany.java.DokanyDriver.start(DokanyDriver.java:72)
... 5 more
cryptomator.0.log
1 12:30:49.059 [main] INFO org.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.5.8 on Windows 10 10.0 (amd64)
2 12:30:49.617 [JavaFX Application Thread] INFO o.c.ui.launcher.FxApplicationStarter - JavaFX Runtime started.
3 12:30:49.646 [JavaFX Application Thread] INFO org.cryptomator.jni.FunctionsLoader - loaded WinFunctions.dll
4 12:31:06.502 [JavaFX Application Thread] WARN o.c.keychain.KeychainManager - LOAD
5 12:31:06.504 [JavaFX Application Thread] INFO o.c.k.WindowsProtectedKeychainAccess - Unable to load existing keychain file, creating new keychain.
6 12:31:07.508 [App Scheduled Executor 01] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\User\AppData\Roaming\Cryptomator\settings.json
7 12:31:34.977 [App Scheduled Executor 01] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\User\AppData\Roaming\Cryptomator\settings.json
8 12:31:38.903 [App Scheduled Executor 02] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\User\AppData\Roaming\Cryptomator\settings.json
9 12:31:40.317 [JavaFX Application Thread] INFO o.cryptomator.ui.fxapp.UpdateChecker - Current version: 1.5.8, lastest version: 1.5.8
10 12:31:46.763 [App Scheduled Executor 01] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\User\AppData\Roaming\Cryptomator\settings.json
11 12:31:55.114 [App Scheduled Executor 02] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\User\AppData\Roaming\Cryptomator\settings.json
12 12:32:20.654 [JavaFX Application Thread] WARN o.c.keychain.KeychainManager - LOAD
13 12:32:21.660 [App Scheduled Executor 01] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\User\AppData\Roaming\Cryptomator\settings.json
14 12:32:26.703 [App Scheduled Executor 02] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\User\AppData\Roaming\Cryptomator\settings.json
15 12:32:32.299 [App Scheduled Executor 01] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\User\AppData\Roaming\Cryptomator\settings.json
16 12:32:37.789 [App Scheduled Executor 02] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\User\AppData\Roaming\Cryptomator\settings.json
17 12:32:43.466 [App Scheduled Executor 01] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\User\AppData\Roaming\Cryptomator\settings.json
18 12:32:44.401 [JavaFX Application Thread] WARN o.c.keychain.KeychainManager - LOAD
19 12:32:46.617 [App Scheduled Executor 01] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\User\AppData\Roaming\Cryptomator\settings.json
20 12:32:49.862 [App Scheduled Executor 02] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\User\AppData\Roaming\Cryptomator\settings.json
21 12:32:51.603 [App Scheduled Executor 01] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\User\AppData\Roaming\Cryptomator\settings.json
22 12:32:53.804 [App Scheduled Executor 02] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\User\AppData\Roaming\Cryptomator\settings.json
23 12:32:57.922 [App Scheduled Executor 01] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\User\AppData\Roaming\Cryptomator\settings.json
24 12:33:01.311 [App Scheduled Executor 02] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\User\AppData\Roaming\Cryptomator\settings.json
25 12:33:14.179 [App Background Thread 004] INFO org.cryptomator.common.vaults.Vault - Storing file name length limit of 220
26 12:33:14.736 [App Background Thread 004] INFO com.dokany.java.DokanyDriver - Dokany version: 140
27 12:33:14.737 [App Background Thread 004] INFO com.dokany.java.DokanyDriver - Dokany driver version: 400
28 12:33:14.755 [App Background Thread 005] WARN com.dokany.java.DokanyDriver - Error while mounting
29 java.lang.IllegalStateException: Mount failed: Driver answer that something is wrong.
30 at com.dokany.java.DokanyDriver.start(DokanyDriver.java:72)
31 at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
32 at java.base/java.util.concurrent.FutureTask.run(Unknown Source)
33 at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
34 at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
35 at java.base/java.lang.Thread.run(Unknown Source)
36 12:33:14.756 [App Background Thread 004] ERROR o.c.frontend.dokany.MountFactory - Mounting failed.
37 java.util.concurrent.ExecutionException: java.lang.IllegalStateException: Mount failed: Driver answer that something is wrong.
38 at java.base/java.util.concurrent.FutureTask.report(Unknown Source)
39 at java.base/java.util.concurrent.FutureTask.get(Unknown Source)
40 at org.cryptomator.frontend.dokany.Mount.mount(Mount.java:36)
41 at org.cryptomator.frontend.dokany.MountFactory.mount(MountFactory.java:119)
42 at org.cryptomator.common.vaults.DokanyVolume.mount(DokanyVolume.java:52)
43 at org.cryptomator.common.vaults.Vault.unlock(Vault.java:129)
44 at org.cryptomator.ui.unlock.UnlockWorkflow.attemptUnlock(UnlockWorkflow.java:103)
45 at org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:80)
46 at org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:43)
47 at javafx.concurrent.Task$TaskCallable.call(Task.java:1425)
48 at java.base/java.util.concurrent.FutureTask.run(Unknown Source)
49 at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
50 at java.base/java.util.concurrent.FutureTask.run(Unknown Source)
51 at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
52 at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
53 at java.base/java.lang.Thread.run(Unknown Source)
54 Caused by: java.lang.IllegalStateException: Mount failed: Driver answer that something is wrong.
55 at com.dokany.java.DokanyDriver.start(DokanyDriver.java:72)
56 ... 5 common frames omitted
57 12:33:14.756 [App Background Thread 004] ERROR o.c.ui.unlock.UnlockWorkflow - Unlock failed for technical reasons.
58 org.cryptomator.common.vaults.Volume$VolumeException: Unable to mount Filesystem
59 at org.cryptomator.common.vaults.DokanyVolume.mount(DokanyVolume.java:57)
60 at org.cryptomator.common.vaults.Vault.unlock(Vault.java:129)
61 at org.cryptomator.ui.unlock.UnlockWorkflow.attemptUnlock(UnlockWorkflow.java:103)
62 at org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:80)
63 at org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:43)
64 at javafx.concurrent.Task$TaskCallable.call(Task.java:1425)
65 at java.base/java.util.concurrent.FutureTask.run(Unknown Source)
66 at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
67 at java.base/java.util.concurrent.FutureTask.run(Unknown Source)
68 at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
69 at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
70 at java.base/java.lang.Thread.run(Unknown Source)
71 Caused by: org.cryptomator.frontend.dokany.MountFailedException: java.lang.IllegalStateException: Mount failed: Driver answer that something is wrong.
72 at org.cryptomator.frontend.dokany.MountFactory.mount(MountFactory.java:128)
73 at org.cryptomator.common.vaults.DokanyVolume.mount(DokanyVolume.java:52)
74 ... 11 common frames omitted
75 Caused by: java.lang.IllegalStateException: Mount failed: Driver answer that something is wrong.
76 at com.dokany.java.DokanyDriver.start(DokanyDriver.java:72)
77 ... 5 common frames omitted
78 12:33:15.189 [App Scheduled Executor 01] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\User\AppData\Roaming\Cryptomator\settings.json
VERSIONS
- Windows 10 Enterprise LTSC (Version 1809 Build 17763.1518)
- Cryptomator v1.5.8-x64 (and a couple previous versions as well)
HOW TO REPRODUCE
- Select vault
- Click the
Unlock...
button - Enter vault’s password and click the
Unlock
button
TROUBLESHOOTING STEPS TAKEN SO FAR
REINSTALLATION
- Uninstalled from Control Panel -> Programs And Features
- Rebooted
- Deleted the
C:\Program Files\Cryptomator
folder - Deleted the
%appdata%\Roaming\Cryptomator
folder - Rebooted again
- Reinstalled
Cryptomator-1.5.8-x64.exe
CREATING A NEW VAULT
- Click the
Add Vault
button - Follow instructions
- Follow steps to reproduce
WORKAROUND
It will almost always fail the first time but will almost always work the second time around.
It has become muscle memory to wait for the error message to pop, to press cancel and re-enter my password.
Not having a lot of time lately, I never got around to report it, thinking I surely am not the only one experiencing this and that the subsequent version would fix it but we are a few versions past that and althought it seems there were a few similar reports, I was not able to find a solution that fixed it for me.
Any help appreciated.
Thank you!
