Big Sur 11.2.3, M1 Mac Mini, Cryptomator 1.5.13 (dmg-2755.123), MacFUSE 4.1.0. Most recent log is at the bottom.
When I unlock a vault, a Finder window opens and I can see the contents, and an icon appears that acts like a network drive. Yay.
Two issues.
First: An icon for the network mount does not appear in Locations in Finder. I would like this to happen like it does for my USB drive and my SMB mount. I have dragged the mount icon over to the Locations bar, but when the second problem happens, the shortcut becomes useless.
Second, way more important: After a few minutes, the Finder window for the vault closes, the drive icon disappears, but while Cryptomator reports that the vault is open, the reveal button doesn’t work and I am unable to reach the vault at all. The only way to make it visible again is to lock and reopen the vault. Lather, rinse, repeat. All I have to do to make this behavior happen is let it sit there.
Other: The vault is stored in a Dropbox. I’m still in the middle of the first giant data dump upload (~300 gig), which is being managed by a Linux machine. It will probably take another two weeks to complete, so I’m aware that not all my files will be visible until the sync actually finishes, but in the meantime I would like to believe that an on-going sync would not cause a crash-like behavior.
Any insight is appreciated.
ETA: When the vault closes in Finder as with item 2 above, it also is unmounted from /Volumes.
MACHINENAME:Cryptomator rnbwpnt$ cat cryptomator0.log
01:02:05.975 [main] INFO org.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.5.13 on Mac OS X 10.16 (x86_64)
01:03:08.147 [JavaFX Application Thread] INFO o.c.ui.launcher.FxApplicationStarter - JavaFX Runtime started.
01:03:12.295 [App Background Thread 003] INFO o.c.ui.unlock.UnlockWorkflow - Unlock of 'Dropbox-Encr' succeeded.
01:03:12.454 [JavaFX Application Thread] INFO o.cryptomator.ui.common.VaultService - Revealed Dropbox-Encr
01:19:59.601 [JavaFX Application Thread] WARN o.cryptomator.ui.fxapp.FxApplication - has visible stages: true
01:20:10.021 [JavaFX Application Thread] WARN o.cryptomator.ui.fxapp.FxApplication - has visible stages: false
03:45:01.621 [Thread-9934] WARN o.c.cryptofs.CryptoPathMapper - Did not find valid content inside of /Volumes/PATH/Dropbox/Cryptomator/Dropbox-Encr/d/BE/6BKF6CT3T2U35IUUVVNRWG72JXXCX6/l9WJNCSnpAdSH3-hORJ9xpRjQBrDiDxZgfVY15A=.c9r
03:45:01.636 [Thread-9992] WARN o.c.cryptofs.CryptoPathMapper - Did not find valid content inside of /Volumes/PATH/Dropbox/Cryptomator/Dropbox-Encr/d/BE/6BKF6CT3T2U35IUUVVNRWG72JXXCX6/l9WJNCSnpAdSH3-hORJ9xpRjQBrDiDxZgfVY15A=.c9r
11:31:42.364 [JavaFX Application Thread] WARN o.cryptomator.ui.fxapp.FxApplication - has visible stages: true
11:31:44.827 [JavaFX Application Thread] WARN o.cryptomator.ui.fxapp.FxApplication - has visible stages: false
03:35:35.689 [JavaFX Application Thread] WARN o.cryptomator.ui.fxapp.FxApplication - has visible stages: true
03:35:45.666 [JavaFX Application Thread] INFO o.cryptomator.ui.fxapp.UpdateChecker - Current version: 1.5.13, lastest version: 1.5.13
03:35:46.410 [JavaFX Application Thread] INFO o.cryptomator.ui.common.VaultService - Revealed Dropbox-Encr
03:38:38.534 [App Background Thread 006] INFO o.c.frontend.fuse.mount.MacMounter - Already unmounted
03:38:38.543 [JavaFX Application Thread] INFO org.cryptomator.ui.lock.LockWorkflow - Lock of Dropbox-Encr succeeded.
03:38:42.389 [App Background Thread 006] INFO o.c.ui.unlock.UnlockWorkflow - Unlock of 'Dropbox-Encr' succeeded.
03:38:43.612 [JavaFX Application Thread] INFO o.cryptomator.ui.common.VaultService - Revealed Dropbox-Encr
03:38:46.401 [JavaFX Application Thread] WARN o.cryptomator.ui.fxapp.FxApplication - has visible stages: false
03:41:02.948 [JavaFX Application Thread] INFO o.cryptomator.ui.common.VaultService - Revealed Dropbox-Encr
03:42:34.595 [JavaFX Application Thread] WARN o.cryptomator.ui.fxapp.FxApplication - has visible stages: true
03:42:44.706 [JavaFX Application Thread] WARN o.cryptomator.ui.fxapp.FxApplication - has visible stages: false
03:42:49.830 [App Background Thread 004] INFO o.c.frontend.fuse.mount.MacMounter - Already unmounted
03:42:49.832 [JavaFX Application Thread] INFO org.cryptomator.ui.lock.LockWorkflow - Lock of Dropbox-Encr succeeded.
03:42:57.334 [App Background Thread 004] INFO o.c.ui.unlock.UnlockWorkflow - Unlock of 'Dropbox-Encr' succeeded.
03:42:57.468 [JavaFX Application Thread] INFO o.cryptomator.ui.common.VaultService - Revealed Dropbox-Encr
03:57:08.079 [JavaFX Application Thread] WARN o.cryptomator.ui.fxapp.FxApplication - has visible stages: true
04:03:17.450 [JavaFX Application Thread] WARN o.cryptomator.ui.fxapp.FxApplication - has visible stages: false
04:19:22.010 [App Background Thread 006] INFO o.c.frontend.fuse.mount.MacMounter - Already unmounted
04:19:22.016 [JavaFX Application Thread] INFO org.cryptomator.ui.lock.LockWorkflow - Lock of Dropbox-Encr succeeded.
04:19:28.799 [App Background Thread 006] INFO o.c.ui.unlock.UnlockWorkflow - Unlock of 'Dropbox-Encr' succeeded.
04:19:29.311 [JavaFX Application Thread] INFO o.cryptomator.ui.common.VaultService - Revealed Dropbox-Encr
04:21:12.791 [JavaFX Application Thread] WARN o.cryptomator.ui.fxapp.FxApplication - has visible stages: true
04:21:18.170 [App Scheduled Executor 01] INFO o.c.common.settings.SettingsProvider - Settings saved to /Users/rnbwpnt/Library/Application Support/Cryptomator/settings.json
04:21:32.661 [JavaFX Application Thread] WARN o.cryptomator.ui.fxapp.FxApplication - has visible stages: false
04:32:36.669 [JavaFX Application Thread] WARN o.cryptomator.ui.fxapp.FxApplication - has visible stages: true
04:33:05.254 [JavaFX Application Thread] INFO o.cryptomator.ui.fxapp.UpdateChecker - Current version: 1.5.13, lastest version: 1.5.13
04:34:42.385 [App Background Thread 004] INFO o.c.frontend.fuse.mount.MacMounter - Already unmounted
04:34:42.389 [JavaFX Application Thread] INFO org.cryptomator.ui.lock.LockWorkflow - Lock of Dropbox-Encr succeeded.
04:34:48.898 [App Background Thread 004] INFO o.c.ui.unlock.UnlockWorkflow - Unlock of 'Dropbox-Encr' succeeded.
04:34:48.967 [JavaFX Application Thread] INFO o.cryptomator.ui.common.VaultService - Revealed Dropbox-Encr
04:41:35.215 [JavaFX Application Thread] INFO o.cryptomator.ui.common.VaultService - Revealed Dropbox-Encr
04:41:44.499 [JavaFX Application Thread] WARN o.cryptomator.ui.fxapp.FxApplication - has visible stages: false
