More Than One Entry of Vault In Upper Left (NOT Quick Access) of File Explorer (Win 11)
I’ve seen where others are getting multiple entries of the Vault in the Quick Access area of File Explorer but I have two entries in the “Home Area” (upper left). The first time I posted this I received a reply with a link to removing the duplicate entries from the Quick Access area but I do not believe that applies to my issue as it is not in the Quick Access area. I would have replied to that post but Infeo closed it. Am I missing something? Should the issue about the Quick Access area apply to my issue as well?
It is the same issue.
Cryptomator has a feature called “Quick Access”. By coincidence, the Windows Explorer has an entry/area that is named the same. But Cryptomator does not use the Windows Explorter Quick Access area, but the general left upper list in the Windows Explorer. If you compare screenshots on the other thread, you’ll notice the duplication happens in the same area.
