Is it possible to sync with MEGA drive on an android? Do I need the api or can I use this method, just use something like Sync for MEGA?
Yes, it’s possible to sync with MEGA Drive on Android. You can use apps like Sync for MEGA for easy integration without needing the API. However, for advanced control, the MEGA API can be helpful.
Staff edit: Removed ad for different app not related to the topic.
Yes, @Caspian gave you one option, And I am working on putting instructions together That will let you use another option As well.
There’s an application available on GitHub that lets you directly access your files on Mega so rather than having to synchronize your files down from Mega to your phone which you may not want to do because you have so many files in the server. my solution allows you to leave all of the files on the clound but still access them and I’ll have that available hopefully in about a week.
So you have two options available depending upon how much data you want synchronized or if you want it synchronized down to your phone.
