I have a vault established for each cloud service I have an account with (Dropbox, Onedive, Google Drive, pCloud and Sync). Every day up to today I could successfully open each vault. It is not an incorrect password issue as I use a password manager. Today I cannot access ANY of these vaults. Each one is reporting an error code. I have made no changes to anything, nothing has been moved or deleted, no hardware changes…nothing different…just…boom!!!
I attempted to open each one by going directly to the vault file and no-go. Same error message
Here are the error details for one of them
Error Code S4DB:IV2H:I3UI
org.cryptomator.common.mount.MountPointPreparationException: java.nio.file.FileAlreadyExistsException: C:\Users\will-\.~$Sync Vault.tmp
at org.cryptomator.desktop@1.8.0/org.cryptomator.common.mount.MountWithinParentUtil.prepareParentNoMountPoint(MountWithinParentUtil.java:32)
at org.cryptomator.desktop@1.8.0/org.cryptomator.common.mount.Mounter$SettledMounter.prepareMountPoint(Mounter.java:101)
at org.cryptomator.desktop@1.8.0/org.cryptomator.common.mount.Mounter$SettledMounter.prepare(Mounter.java:73)
at org.cryptomator.desktop@1.8.0/org.cryptomator.common.mount.Mounter.mount(Mounter.java:133)
at org.cryptomator.desktop@1.8.0/org.cryptomator.common.vaults.Vault.unlock(Vault.java:150)
at org.cryptomator.desktop@1.8.0/org.cryptomator.ui.keyloading.KeyLoadingStrategy.use(KeyLoadingStrategy.java:79)
at org.cryptomator.desktop@1.8.0/org.cryptomator.ui.unlock.UnlockWorkflow.attemptUnlock(UnlockWorkflow.java:70)
at org.cryptomator.desktop@1.8.0/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:60)
at org.cryptomator.desktop@1.8.0/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:31)
at javafx.graphics@19.0.2.1/javafx.concurrent.Task$TaskCallable.call(Unknown Source)
Caused by: java.nio.file.FileAlreadyExistsException: C:\Users\will-\.~$Sync Vault.tmp
... 15 more
