This happens after upgrade from v1.4.16 > 17. Reverting to 1.4.16 + reboot fixes the problem.
Please fix or let me know what to do. Thanks :o)
08:19:29.852 [main] INFO org.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.4.17 on Mac OS X 10.14.6 (x86_64)
08:19:29.928 [main] INFO o.c.launcher.IpcProtocolImpl - Received launch args:
08:19:30.083 [JavaFX Application Thread] INFO org.cryptomator.launcher.Cryptomator - JavaFX application started.
08:19:30.160 [JavaFX Application Thread] INFO org.cryptomator.jni.JniModule - loaded libMacFunctions.dylib
08:19:30.657 [Background Thread 1] ERROR o.cryptomator.ui.model.AutoUnlocker - Auto unlock failed.
java.nio.file.FileSystemException: /Users/peke/_mnt/Mine: Device not configured
at java.base/sun.nio.fs.UnixException.translateToIOException(UnixException.java:100)
at java.base/sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:111)
at java.base/sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:116)
at java.base/sun.nio.fs.UnixFileSystemProvider.newDirectoryStream(UnixFileSystemProvider.java:412)
at java.base/java.nio.file.Files.newDirectoryStream(Files.java:471)
at org.cryptomator.ui.model.FuseVolume.checkProvidedMountPoint(FuseVolume.java:65)
at org.cryptomator.ui.model.FuseVolume.mount(FuseVolume.java:51)
at org.cryptomator.ui.model.Vault.unlock(Vault.java:115)
at org.cryptomator.ui.model.AutoUnlocker.unlockSilently(AutoUnlocker.java:76)
at org.cryptomator.ui.model.AutoUnlocker.unlockAll(AutoUnlocker.java:57)
at org.cryptomator.ui.model.AutoUnlocker.lambda$unlockAllSilently$0(AutoUnlocker.java:45)
08:19:31.172 [JavaFX Application Thread] INFO o.c.ui.controllers.WelcomeController - Current version: 1.4.17, lastest version: 1.4.17
08:19:31.281 [Background Thread 1] ERROR o.cryptomator.ui.model.AutoUnlocker - Auto unlock failed.
java.nio.file.FileSystemException: /Users/peke/_mnt/SAP: Device not configured
at org.cryptomator.ui.model.AutoUnlocker.unlockAll(AutoUnlocker.java:60)
08:19:43.733 [JavaFX Application Thread] ERROR o.c.ui.controllers.UnlockController - Unlock failed for technical reasons.
at org.cryptomator.ui.controllers.UnlockController.lambda$didClickUnlockButton$0(UnlockController.java:494)
08:19:46.774 [JavaFX Application Thread] ERROR o.c.ui.controllers.UnlockController - Unlock failed for technical reasons.
