Subject says it all β my license key is lost. What can I do to recover it???
Hey and welcome to the community !
You can send me the email address in a direct message with which you bought Cryptomator to send the license to you again.
Iβm not sure which E-Mail address I used, but it is probably one of two: Either β
foo -OR-
bar
β the GMail address being the more likely.
I recommend you try both. I also have a third E-Mail address, but itβs unlikely that I used that one to buy Cryptomator.
However, if neither of the above two addresses work, let me know and Iβll send you that third address to try.
And, THANK YOU, very much, for taking the time to help me out!
Will check it and just removed your mail address for privacy reason
Just send you a message with your license key.
