Maybe I posted my issue on the wrong platform, if so please forgive me.
I have described my issue with a lost folder in Github(https://github.com/cryptomator/cryptomator/issues/1475).
And in addition to the issue of the lost folder, now I cannot open my vault using Cryptomator + Google File Stream(GFS) on Windows 10. I have already confirmed that this is not a GFS issue.
Below is the error code for the issue on opening my vault:
java.io.IOException: 파일이 이미 있으므로 만들 수 없습니다
at java.base/sun.nio.ch.FileDispatcherImpl.read0(Native Method)
at java.base/sun.nio.ch.FileDispatcherImpl.read(Unknown Source)
at java.base/sun.nio.ch.IOUtil.readIntoNativeBuffer(Unknown Source)
at java.base/sun.nio.ch.IOUtil.read(Unknown Source)
at java.base/sun.nio.ch.FileChannelImpl.read(Unknown Source)
at java.base/sun.nio.ch.ChannelInputStream.read(Unknown Source)
at java.base/java.nio.file.Files.read(Unknown Source)
at java.base/java.nio.file.Files.readAllBytes(Unknown Source)
at org.cryptomator.cryptofs.migration.Migrators.needsMigration(Migrators.java:81)
at org.cryptomator.common.vaults.VaultListManager.determineVaultState(VaultListManager.java:129)
at org.cryptomator.common.vaults.VaultListManager.redetermineVaultState(VaultListManager.java:112)
at org.cryptomator.ui.mainwindow.VaultListController.selectedVaultDidChange(VaultListController.java:65)
at com.sun.javafx.binding.ExpressionHelper$Generic.fireValueChangedEvent(ExpressionHelper.java:360)
at com.sun.javafx.binding.ExpressionHelper.fireValueChangedEvent(ExpressionHelper.java:80)
at javafx.beans.property.ObjectPropertyBase.fireValueChangedEvent(ObjectPropertyBase.java:106)
at javafx.beans.property.ObjectPropertyBase.markInvalid(ObjectPropertyBase.java:113)
at javafx.beans.property.ObjectPropertyBase$Listener.invalidated(ObjectPropertyBase.java:234)
at com.sun.javafx.binding.ExpressionHelper$SingleInvalidation.fireValueChangedEvent(ExpressionHelper.java:136)
at javafx.beans.property.ReadOnlyObjectPropertyBase.fireValueChangedEvent(ReadOnlyObjectPropertyBase.java:74)
at javafx.beans.property.ReadOnlyObjectWrapper.fireValueChangedEvent(ReadOnlyObjectWrapper.java:102)
at javafx.beans.property.ObjectPropertyBase.set(ObjectPropertyBase.java:147)
at javafx.scene.control.SelectionModel.setSelectedItem(SelectionModel.java:105)
at javafx.scene.control.MultipleSelectionModelBase.lambda$new$0(MultipleSelectionModelBase.java:67)
at javafx.beans.property.ReadOnlyIntegerPropertyBase.fireValueChangedEvent(ReadOnlyIntegerPropertyBase.java:72)
at javafx.beans.property.ReadOnlyIntegerWrapper.fireValueChangedEvent(ReadOnlyIntegerWrapper.java:102)
at javafx.beans.property.IntegerPropertyBase.markInvalid(IntegerPropertyBase.java:114)
at javafx.beans.property.IntegerPropertyBase.set(IntegerPropertyBase.java:148)
at javafx.scene.control.SelectionModel.setSelectedIndex(SelectionModel.java:69)
at javafx.scene.control.MultipleSelectionModelBase.select(MultipleSelectionModelBase.java:412)
at javafx.scene.control.MultipleSelectionModelBase.clearAndSelect(MultipleSelectionModelBase.java:360)
at javafx.scene.control.ListView$ListViewBitSetSelectionModel.clearAndSelect(ListView.java:1449)
at com.sun.javafx.scene.control.behavior.CellBehaviorBase.simpleSelect(CellBehaviorBase.java:282)
at com.sun.javafx.scene.control.behavior.CellBehaviorBase.doSelect(CellBehaviorBase.java:246)
at com.sun.javafx.scene.control.behavior.CellBehaviorBase.mousePressed(CellBehaviorBase.java:176)
at com.sun.javafx.scene.control.inputmap.InputMap.handle(InputMap.java:274)
at com.sun.javafx.event.CompositeEventHandler$NormalEventHandlerRecord.handleBubblingEvent(CompositeEventHandler.java:247)
at com.sun.javafx.event.CompositeEventHandler.dispatchBubblingEvent(CompositeEventHandler.java:80)
at com.sun.javafx.event.EventHandlerManager.dispatchBubblingEvent(EventHandlerManager.java:234)
at com.sun.javafx.event.EventHandlerManager.dispatchBubblingEvent(EventHandlerManager.java:191)
at com.sun.javafx.event.CompositeEventDispatcher.dispatchBubblingEvent(CompositeEventDispatcher.java:59)
at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:58)
at com.sun.javafx.event.EventDispatchChainImpl.dispatchEvent(EventDispatchChainImpl.java:114)
at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:56)
at com.sun.javafx.event.EventUtil.fireEventImpl(EventUtil.java:74)
at com.sun.javafx.event.EventUtil.fireEvent(EventUtil.java:54)
at javafx.event.Event.fireEvent(Event.java:198)
at javafx.scene.Scene$MouseHandler.process(Scene.java:3856)
at javafx.scene.Scene.processMouseEvent(Scene.java:1851)
at javafx.scene.Scene$ScenePeerListener.mouseEvent(Scene.java:2584)
at com.sun.javafx.tk.quantum.GlassViewEventHandler$MouseEventNotification.run(GlassViewEventHandler.java:409)
at com.sun.javafx.tk.quantum.GlassViewEventHandler$MouseEventNotification.run(GlassViewEventHandler.java:299)
at com.sun.javafx.tk.quantum.GlassViewEventHandler.lambda$handleMouseEvent$2(GlassViewEventHandler.java:447)
at com.sun.javafx.tk.quantum.QuantumToolkit.runWithoutRenderLock(QuantumToolkit.java:412)
at com.sun.javafx.tk.quantum.GlassViewEventHandler.handleMouseEvent(GlassViewEventHandler.java:446)
at com.sun.glass.ui.View.handleMouseEvent(View.java:556)
at com.sun.glass.ui.View.notifyMouse(View.java:942)
at com.sun.glass.ui.win.WinApplication._runLoop(Native Method)
at com.sun.glass.ui.win.WinApplication.lambda$runLoop$3(WinApplication.java:174)
Please help with both issues.
Edit: Just to clarify, the Android Cryptomator app has no problems opening the said vault. But the issue of the lost folders is a common issue between platforms.
