Hi, I searched the archives but didn’t find an answer.
I’m running Windows 10
Cryptomator 1.5.14
I can start Cryptomator manually. But when I click “Launch Cryptomator on system start” it fails. This has been happening for some time, across numerous Cryptomator updates. I get a window
“An unexpected error occurred”
org.cryptomator.integrations.autostart.ToggleAutoStartFailedException: Enabling autostart using the startup folder failed. Windows error code: 80070003
at org.cryptomator.windows.autostart.WindowsAutoStart.enable(WindowsAutoStart.java:51)
at org.cryptomator.ui.preferences.GeneralPreferencesController.lambda$toggleAutoStart$3(GeneralPreferencesController.java:142)
at java.base/java.util.Optional.ifPresent(Unknown Source)
at org.cryptomator.ui.preferences.GeneralPreferencesController.toggleAutoStart(GeneralPreferencesController.java:138)
at jdk.internal.reflect.GeneratedMethodAccessor43.invoke(Unknown Source)
at javafx.fxml.FXMLLoader$MethodHandler.invoke(FXMLLoader.java:1859)
at javafx.fxml.FXMLLoader$ControllerMethodEventHandler.handle(FXMLLoader.java:1729)
at com.sun.javafx.event.CompositeEventHandler.dispatchBubblingEvent(CompositeEventHandler.java:86)
at com.sun.javafx.event.EventHandlerManager.dispatchBubblingEvent(EventHandlerManager.java:234)
at com.sun.javafx.event.EventHandlerManager.dispatchBubblingEvent(EventHandlerManager.java:191)
at com.sun.javafx.event.CompositeEventDispatcher.dispatchBubblingEvent(CompositeEventDispatcher.java:59)
at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:58)
at com.sun.javafx.event.EventDispatchChainImpl.dispatchEvent(EventDispatchChainImpl.java:114)
at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:56)
at com.sun.javafx.event.EventUtil.fireEventImpl(EventUtil.java:74)
at com.sun.javafx.event.EventUtil.fireEvent(EventUtil.java:49)
at javafx.event.Event.fireEvent(Event.java:198)
at javafx.scene.Node.fireEvent(Node.java:8886)
at javafx.scene.control.CheckBox.fire(CheckBox.java:240)
at com.sun.javafx.scene.control.behavior.ButtonBehavior.mouseReleased(ButtonBehavior.java:208)
at com.sun.javafx.scene.control.inputmap.InputMap.handle(InputMap.java:274)
at com.sun.javafx.event.CompositeEventHandler$NormalEventHandlerRecord.handleBubblingEvent(CompositeEventHandler.java:247)
at com.sun.javafx.event.CompositeEventHandler.dispatchBubblingEvent(CompositeEventHandler.java:80)
at com.sun.javafx.event.EventUtil.fireEvent(EventUtil.java:54)
at javafx.scene.Scene$MouseHandler.process(Scene.java:3856)
at javafx.scene.Scene.processMouseEvent(Scene.java:1851)
at javafx.scene.Scene$ScenePeerListener.mouseEvent(Scene.java:2584)
at com.sun.javafx.tk.quantum.GlassViewEventHandler$MouseEventNotification.run(GlassViewEventHandler.java:409)
at com.sun.javafx.tk.quantum.GlassViewEventHandler$MouseEventNotification.run(GlassViewEventHandler.java:299)
at com.sun.javafx.tk.quantum.GlassViewEventHandler.lambda$handleMouseEvent$2(GlassViewEventHandler.java:447)
at com.sun.javafx.tk.quantum.QuantumToolkit.runWithoutRenderLock(QuantumToolkit.java:412)
at com.sun.javafx.tk.quantum.GlassViewEventHandler.handleMouseEvent(GlassViewEventHandler.java:446)
at com.sun.glass.ui.View.handleMouseEvent(View.java:556)
at com.sun.glass.ui.View.notifyMouse(View.java:942)
at com.sun.glass.ui.win.WinApplication._runLoop(Native Method)
at com.sun.glass.ui.win.WinApplication.lambda$runLoop$3(WinApplication.java:174)
