Hallo!
Ich nutze IceDrive als Cloud Storage(unterstützen WebDav) und wollte dort einen Tresor erstellen.
Das erstellen funktioniert leider gar nicht, folgende Fehlermeldung erscheint:
java.io.IOException: Error during file system creation.
at org.cryptomator.cryptofs.CryptoFileSystems.create(CryptoFileSystems.java:53)
at org.cryptomator.cryptofs.CryptoFileSystemProvider.newFileSystem(CryptoFileSystemProvider.java:302)
at org.cryptomator.cryptofs.CryptoFileSystemProvider.newFileSystem(CryptoFileSystemProvider.java:94)
at org.cryptomator.cryptofs.CryptoFileSystemProvider.newFileSystem(CryptoFileSystemProvider.java:135)
at org.cryptomator.ui.addvaultwizard.CreateNewVaultPasswordController.initializeVault(CreateNewVaultPasswordController.java:173)
at org.cryptomator.ui.addvaultwizard.CreateNewVaultPasswordController.lambda$showRecoveryKeyScene$1(CreateNewVaultPasswordController.java:134)
at org.cryptomator.ui.common.Tasks$TaskImpl.call(Tasks.java:139)
Caused by: java.io.UncheckedIOException: java.nio.file.NoSuchFileException: I:\Test
at org.cryptomator.cryptofs.CryptoFileStore.getFileStore(CryptoFileStore.java:40)
at org.cryptomator.cryptofs.CryptoFileStore.<init>(CryptoFileStore.java:31)
at org.cryptomator.cryptofs.CryptoFileStore_Factory.newInstance(CryptoFileStore_Factory.java:38)
at org.cryptomator.cryptofs.CryptoFileStore_Factory.get(CryptoFileStore_Factory.java:29)
at org.cryptomator.cryptofs.CryptoFileStore_Factory.get(CryptoFileStore_Factory.java:8)
at org.cryptomator.cryptofs.DaggerCryptoFileSystemProviderComponent$CryptoFileSystemComponentImpl.cryptoFileSystem(DaggerCryptoFileSystemProviderComponent.java:325)
... 15 more
Caused by: java.nio.file.NoSuchFileException: I:\Test
at java.base/sun.nio.fs.WindowsLinkSupport.getFinalPath(Unknown Source)
at java.base/sun.nio.fs.WindowsFileStore.create(Unknown Source)
at java.base/sun.nio.fs.WindowsFileSystemProvider.getFileStore(Unknown Source)
at org.cryptomator.cryptofs.CryptoFileStore.getFileStore(CryptoFileStore.java:38)
... 27 more
Ich nutze Windows 10 und habe die aktuellste Version von Cryptomator installiert.
Hat da jemand eine Idee woran das liegen kann? Ist das ein Bug oder mache ich da was falsch?
Vielen Dank!
