How do I mount a vault as a network drive?
Windows
Cryptomator 1.6.1
infeo
#2
Inside the Cryptomator application, open the general preferences:
Select the “Virtual Drive” tab and pick from the dropdown menu “WebDAV”:
If the vault was unlocked during the change, you need to lock and unlock it again.
