ccchan
March 24, 2018, 9:48am
#1
Hi~
Trying to use sanitizer 's decryptFile function.
From the web I only found little info.
Suppose I put on google drive with G:\my drive\vault\masterkey.xxx
in command prompt I call up java -jar sanitizer decryptfile -vault “G\my drive\vault”
it then ask for password. (done)
it then
"enter absolute path of an encrypted file:" <----------------------------
the vault itself, assume a new one I made for testing,
only have:
/test.pdf
and now I don’t know what to enter into the “ask for absolute path” question.
is it…
/? (result in: Given path is not absolute.)
/test.pdf?
or it is G:\my drive\vault\ with the encrypted path?
thank in advance.
ccchan
March 24, 2018, 9:54am
#2
from this post,
it seems in the <----------------- question,
one have to enter the encrypted path?
I am using google 's file stream, seems differ from the above user’s situation.
ccchan
March 24, 2018, 9:56am
#3
from this post:
$ java -jar sanitizer-0.13.jar decryptFile -vault /Users/Eduardo/Cryptomator_vault/
Cryptomator vault sanitizer v0.13
Vault password:
Enter absolute path of an encrypted file: /Users/Eduardo/Cryptomator_vault/d/35/JG366DHSZ7C2CF7JS6NHVBSAROACEH/2RYXDGZIR6S4W24IB5POARRVCMIOKMBXGFXZINSRLU5NU4MMAY6Q====
how the hell I know
is the file I want to decrypt !?
thanks
Use the encryptPath
command first to determine the encrypted path. After that you can use decryptFile
