Green marks in cloud (synchronisation finished) are missing when using cryptomator
We’re using Cryptomator with our telekom magenta cloud and there’re no green marks at the folders (saying that the folder is completely synchronised). It’s the same by using cryptomator with dropbox and is there any fix for that problem? We’re using the cloud with different people and it’s important for us to see if the files synchronised.
Thanks and best wishes
Schippinho
Please have a look at the encrypted files within your local magenta cloud drive. These are the files that are synced with your Magenta cloud and therefore here you’ll find the green marks.
sync
I guess you look at the unencrypted files within your vault (the WebDAV Network Drive).
There you will not find the green marks.
