More on the same:
After rebooting and again trying the WebDAV interface instead of FUSE, the vault opens after a while, but is still very slow. Working with files and folders is technically impossible.
I turned on debug mode and this is the log file:
17:07:51.603 [main] INFO org.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.4.1 on Linux 4.15.0-43-generic (amd64)
17:07:51.866 [main] INFO o.c.launcher.FileOpenRequestHandler - Unable to setOpenFileHandler, probably not supported on this OS.
17:07:52.424 [JavaFX Application Thread] INFO o.c.launcher.MainApplication - JavaFX application started.
17:07:52.533 [JavaFX Application Thread] INFO o.c.common.settings.SettingsProvider - Settings loaded from /home/kasimir/.Cryptomator/settings.json
17:07:52.534 [JavaFX Application Thread] DEBUG org.cryptomator.logging.DebugMode - Debug mode initialized
17:07:52.540 [JavaFX Application Thread] DEBUG org.cryptomator.ui.l10n.Localization - Loaded localization default file: /localization/en.txt
17:07:52.540 [JavaFX Application Thread] DEBUG org.cryptomator.ui.l10n.Localization - Detected language "de" and region "DE"
17:07:52.548 [JavaFX Application Thread] TRACE org.cryptomator.ui.l10n.Localization - Attempting to load localization from: /localization/de_DE.txt
17:07:52.549 [JavaFX Application Thread] TRACE org.cryptomator.ui.l10n.Localization - Attempting to load localization from: /localization/de.txt
17:07:52.802 [JavaFX Application Thread] INFO o.c.ui.controllers.MainController - Unable to setPreferencesHandler, probably not supported on this OS.
17:07:54.795 [JavaFX Application Thread] INFO o.c.ui.controllers.WelcomeController - Current version: 1.4.1, lastest version: 1.4.1
17:08:49.520 [Background Thread 2] INFO org.eclipse.jetty.util.log - Logging initialized @58895ms to org.eclipse.jetty.util.log.Slf4jLog
17:08:49.652 [Background Thread 2] INFO o.c.frontend.webdav.WebDavServer - Binding server socket to localhost:42427
17:08:49.682 [Background Thread 2] INFO o.e.jetty.server.AbstractConnector - Started ServerConnector@144ecbd1{HTTP/1.1,[http/1.1]}{localhost:42427}
17:08:49.687 [Background Thread 2] INFO org.eclipse.jetty.server.Server - jetty-9.4.12.v20180830; built: 2018-08-30T13:59:14.071Z; git: 27208684755d94a92186989f695db2d7b21ebc51; jvm 9.0.1+11
17:08:49.730 [Background Thread 2] INFO o.e.j.server.handler.ContextHandler - Started o.e.j.s.ServletContextHandler@35db26e3{/,null,AVAILABLE}
17:08:49.730 [Background Thread 2] INFO org.eclipse.jetty.server.Server - Started @59105ms
17:08:49.731 [Background Thread 2] INFO o.c.frontend.webdav.WebDavServer - WebDavServer started.
17:08:49.835 [Background Thread 2] INFO org.eclipse.jetty.server.session - DefaultSessionIdManager workerName=node0
17:08:49.835 [Background Thread 2] INFO org.eclipse.jetty.server.session - No SessionScavenger set, using defaults
17:08:49.837 [Background Thread 2] INFO org.eclipse.jetty.server.session - node0 Scavenging every 660000ms
17:08:49.851 [Background Thread 2] INFO o.a.j.w.server.AbstractWebdavServlet - authenticate-header = Basic realm="Jackrabbit Webdav Server"
17:08:49.852 [Background Thread 2] INFO o.a.j.w.server.AbstractWebdavServlet - csrf-protection = null
17:08:49.852 [Background Thread 2] INFO o.a.j.w.server.AbstractWebdavServlet - createAbsoluteURI = true
17:08:49.853 [Background Thread 2] INFO o.e.j.server.handler.ContextHandler - Started o.e.j.s.ServletContextHandler@39184a83{/D6jamcO0TJWP/DataBox,null,AVAILABLE}
17:08:49.853 [Background Thread 2] INFO o.c.f.w.s.WebDavServletController - WebDavServlet started: /D6jamcO0TJWP/DataBox
17:08:49.872 [Background Thread 2] INFO o.c.f.w.s.WebDavServletController - Mounting http://localhost:42427/D6jamcO0TJWP/DataBox using org.cryptomator.frontend.webdav.mount.LinuxGioMounter
17:08:50.107 [etp939291483-41] DEBUG org.eclipse.jetty.server.HttpChannel - new HttpChannelOverHttp@4fb12647{r=0,c=false,a=IDLE,uri=null,age=0} -> SocketChannelEndPoint@322c1e26{/127.0.0.1:34142<->/127.0.0.1:42427,OPEN,fill=-,flush=-,to=73/30000}{io=0/0,kio=0,kro=0}-><null>,null,HttpChannelState@6323af7d{s=IDLE a=NOT_ASYNC i=true r=IDLE w=false}
17:08:50.161 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - REQUEST for //localhost:42427/D6jamcO0TJWP/DataBox on HttpChannelOverHttp@4fb12647{r=1,c=false,a=IDLE,uri=//localhost:42427/D6jamcO0TJWP/DataBox,age=1}
OPTIONS //localhost:42427/D6jamcO0TJWP/DataBox HTTP/1.1
Host: localhost:42427
Accept-Encoding: gzip, deflate
User-Agent: gvfs/1.36.1
Accept-Language: de-de, de;q=0.9
Connection: keep-alive
17:08:50.163 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@4fb12647{r=1,c=false,a=IDLE,uri=//localhost:42427/D6jamcO0TJWP/DataBox,age=9} onContentComplete
17:08:50.167 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@4fb12647{r=1,c=false,a=IDLE,uri=//localhost:42427/D6jamcO0TJWP/DataBox,age=13} onRequestComplete
17:08:50.169 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@4fb12647{r=1,c=false,a=IDLE,uri=//localhost:42427/D6jamcO0TJWP/DataBox,age=15} handle //localhost:42427/D6jamcO0TJWP/DataBox
17:08:50.171 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@4fb12647{r=1,c=false,a=DISPATCHED,uri=//localhost:42427/D6jamcO0TJWP/DataBox,age=17} action DISPATCH
17:08:50.174 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - sendResponse info=null content=HeapByteBuffer@2567b617[p=0,l=0,c=0,r=0]={<<<>>>} complete=true committing=true callback=Blocker@4e85aeef{null}
17:08:50.175 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - COMMIT for /D6jamcO0TJWP/DataBox on HttpChannelOverHttp@4fb12647{r=1,c=true,a=DISPATCHED,uri=//localhost:42427/D6jamcO0TJWP/DataBox,age=20}
302 null HTTP/1.1
Date: Sun, 27 Jan 2019 16:08:50 GMT
17:08:50.181 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@4fb12647{r=1,c=true,a=COMPLETING,uri=//localhost:42427/D6jamcO0TJWP/DataBox,age=27} action COMPLETE
17:08:50.181 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - COMPLETE for /D6jamcO0TJWP/DataBox written=0
17:08:50.184 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@4fb12647{r=1,c=false,a=IDLE,uri=null,age=0} handle exit, result COMPLETE
17:08:50.186 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - REQUEST for //localhost:42427/D6jamcO0TJWP/DataBox/ on HttpChannelOverHttp@4fb12647{r=2,c=false,a=IDLE,uri=//localhost:42427/D6jamcO0TJWP/DataBox/,age=0}
OPTIONS //localhost:42427/D6jamcO0TJWP/DataBox/ HTTP/1.1
17:08:50.187 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@4fb12647{r=2,c=false,a=IDLE,uri=//localhost:42427/D6jamcO0TJWP/DataBox/,age=1} onContentComplete
17:08:50.188 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@4fb12647{r=2,c=false,a=IDLE,uri=//localhost:42427/D6jamcO0TJWP/DataBox/,age=1} onRequestComplete
17:08:50.188 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@4fb12647{r=2,c=false,a=IDLE,uri=//localhost:42427/D6jamcO0TJWP/DataBox/,age=2} handle //localhost:42427/D6jamcO0TJWP/DataBox/
17:08:50.188 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@4fb12647{r=2,c=false,a=DISPATCHED,uri=//localhost:42427/D6jamcO0TJWP/DataBox/,age=2} action DISPATCH
17:08:50.198 [etp939291483-44] INFO o.c.w.core.filters.LoggingFilter - REQUEST 0:
OPTIONS /D6jamcO0TJWP/DataBox/ HTTP/1.1
17:08:50.978 [etp939291483-44] INFO o.c.w.core.filters.LoggingFilter - RESPONSE 0:
200
DAV: 1, 2
MS-Author-Via: DAV
Allow: OPTIONS, GET, HEAD, TRACE, PROPFIND, PROPPATCH, MKCOL, COPY, PUT, DELETE, MOVE, LOCK, UNLOCK
17:08:50.980 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@4fb12647{r=2,c=false,a=COMPLETING,uri=//localhost:42427/D6jamcO0TJWP/DataBox/,age=793} action COMPLETE
17:08:50.980 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - sendResponse info=null content=HeapByteBuffer@2567b617[p=0,l=0,c=0,r=0]={<<<>>>} complete=true committing=true callback=Blocker@4e85aeef{null}
17:08:50.980 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - COMMIT for /D6jamcO0TJWP/DataBox/ on HttpChannelOverHttp@4fb12647{r=2,c=true,a=COMPLETING,uri=//localhost:42427/D6jamcO0TJWP/DataBox/,age=794}
200 null HTTP/1.1
DAV: 1, 2
MS-Author-Via: DAV
17:08:50.981 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - COMPLETE for /D6jamcO0TJWP/DataBox/ written=0
17:08:50.982 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@4fb12647{r=2,c=false,a=IDLE,uri=null,age=0} handle exit, result COMPLETE
17:08:50.983 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - REQUEST for //localhost:42427/D6jamcO0TJWP/DataBox/ on HttpChannelOverHttp@4fb12647{r=3,c=false,a=IDLE,uri=//localhost:42427/D6jamcO0TJWP/DataBox/,age=0}
PROPFIND //localhost:42427/D6jamcO0TJWP/DataBox/ HTTP/1.1
Depth: 0
Content-Type: application/xml
Content-Length: 146
17:08:50.983 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@4fb12647{r=3,c=false,a=IDLE,uri=//localhost:42427/D6jamcO0TJWP/DataBox/,age=1} handle //localhost:42427/D6jamcO0TJWP/DataBox/
17:08:50.984 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@4fb12647{r=3,c=false,a=DISPATCHED,uri=//localhost:42427/D6jamcO0TJWP/DataBox/,age=1} action DISPATCH
17:08:50.984 [etp939291483-44] INFO o.c.w.core.filters.LoggingFilter - REQUEST 1:
PROPFIND /D6jamcO0TJWP/DataBox/ HTTP/1.1
Content-Length: 146
Depth: 0
17:08:51.068 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@4fb12647{r=3,c=false,a=DISPATCHED,uri=//localhost:42427/D6jamcO0TJWP/DataBox/,age=85} onContent Content@3d4a10d8{HeapByteBufferR@403279ae[p=244,l=390,c=8192,r=146]={PROPFIND /D6jamcO...Length: 146\r\n\r\n<<<<?xml version="1....\n </D:propfind>>>>\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00}}
17:08:51.069 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@4fb12647{r=3,c=false,a=DISPATCHED,uri=//localhost:42427/D6jamcO0TJWP/DataBox/,age=87} onContentComplete
17:08:51.069 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@4fb12647{r=3,c=false,a=DISPATCHED,uri=//localhost:42427/D6jamcO0TJWP/DataBox/,age=87} onRequestComplete
17:08:51.166 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - sendResponse info=null content=HeapByteBuffer@5934c6fb[p=0,l=418,c=418,r=418]={<<<<?xml version="1..../D:multistatus>>>>} complete=true committing=true callback=Blocker@4e85aeef{null}
17:08:51.167 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - COMMIT for /D6jamcO0TJWP/DataBox/ on HttpChannelOverHttp@4fb12647{r=3,c=true,a=DISPATCHED,uri=//localhost:42427/D6jamcO0TJWP/DataBox/,age=185}
207 null HTTP/1.1
Content-Type: text/xml;charset=utf-8
Content-Length: 418
17:08:51.168 [etp939291483-44] INFO o.c.w.core.filters.LoggingFilter - RESPONSE 1:
207
Content-Length: 418
17:08:51.169 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@4fb12647{r=3,c=true,a=COMPLETING,uri=//localhost:42427/D6jamcO0TJWP/DataBox/,age=187} action COMPLETE
17:08:51.169 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - COMPLETE for /D6jamcO0TJWP/DataBox/ written=418
17:08:51.170 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@4fb12647{r=3,c=false,a=IDLE,uri=null,age=0} handle exit, result COMPLETE
17:08:51.171 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - REQUEST for //localhost:42427/D6jamcO0TJWP/ on HttpChannelOverHttp@4fb12647{r=4,c=false,a=IDLE,uri=//localhost:42427/D6jamcO0TJWP/,age=0}
OPTIONS //localhost:42427/D6jamcO0TJWP/ HTTP/1.1
17:08:51.171 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@4fb12647{r=4,c=false,a=IDLE,uri=//localhost:42427/D6jamcO0TJWP/,age=1} onContentComplete
17:08:51.172 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@4fb12647{r=4,c=false,a=IDLE,uri=//localhost:42427/D6jamcO0TJWP/,age=1} onRequestComplete
17:08:51.172 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@4fb12647{r=4,c=false,a=IDLE,uri=//localhost:42427/D6jamcO0TJWP/,age=2} handle //localhost:42427/D6jamcO0TJWP/
17:08:51.173 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@4fb12647{r=4,c=false,a=DISPATCHED,uri=//localhost:42427/D6jamcO0TJWP/,age=3} action DISPATCH
17:08:51.186 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@4fb12647{r=4,c=false,a=COMPLETING,uri=//localhost:42427/D6jamcO0TJWP/,age=16} action COMPLETE
17:08:51.187 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - sendResponse info=null content=HeapByteBuffer@2567b617[p=0,l=0,c=0,r=0]={<<<>>>} complete=true committing=true callback=Blocker@4e85aeef{null}
17:08:51.187 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - COMMIT for /D6jamcO0TJWP/ on HttpChannelOverHttp@4fb12647{r=4,c=true,a=COMPLETING,uri=//localhost:42427/D6jamcO0TJWP/,age=17}
204 null HTTP/1.1
Date: Sun, 27 Jan 2019 16:08:51 GMT
DAV: 1, 2
MS-Author-Via: DAV
Allow: OPTIONS, PROPFIND, GET, HEAD
17:08:51.188 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - COMPLETE for /D6jamcO0TJWP/ written=0
17:08:51.189 [etp939291483-44] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@4fb12647{r=4,c=false,a=IDLE,uri=null,age=0} handle exit, result COMPLETE
17:08:51.194 [etp939291483-45] DEBUG org.eclipse.jetty.server.HttpChannel - new HttpChannelOverHttp@ee1916f{r=0,c=false,a=IDLE,uri=null,age=0} -> SocketChannelEndPoint@266ec3{/127.0.0.1:34144<->/127.0.0.1:42427,OPEN,fill=-,flush=-,to=4/30000}{io=0/0,kio=0,kro=0}-><null>,null,HttpChannelState@419fa1f{s=IDLE a=NOT_ASYNC i=true r=IDLE w=false}
17:08:51.197 [etp939291483-36] DEBUG org.eclipse.jetty.server.HttpChannel - REQUEST for //localhost:42427/D6jamcO0TJWP/ on HttpChannelOverHttp@ee1916f{r=1,c=false,a=IDLE,uri=//localhost:42427/D6jamcO0TJWP/,age=0}
PROPFIND //localhost:42427/D6jamcO0TJWP/ HTTP/1.1
Depth: 0
Content-Length: 146
17:08:51.197 [etp939291483-36] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@ee1916f{r=1,c=false,a=IDLE,uri=//localhost:42427/D6jamcO0TJWP/,age=0} handle //localhost:42427/D6jamcO0TJWP/
17:08:51.198 [etp939291483-36] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@ee1916f{r=1,c=false,a=DISPATCHED,uri=//localhost:42427/D6jamcO0TJWP/,age=0} action DISPATCH
17:08:51.200 [etp939291483-36] DEBUG org.eclipse.jetty.server.HttpChannel - sendResponse info=null content=DirectByteBuffer@6e2c4839[p=0,l=317,c=32768,r=317]={<<<<?xml version="1..../D:multistatus>>>>\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00} complete=false committing=true callback=Blocker@57203108{null}
17:08:51.202 [etp939291483-36] DEBUG org.eclipse.jetty.server.HttpChannel - COMMIT for /D6jamcO0TJWP/ on HttpChannelOverHttp@ee1916f{r=1,c=true,a=DISPATCHED,uri=//localhost:42427/D6jamcO0TJWP/,age=5}
200 null HTTP/1.1
17:08:51.203 [etp939291483-36] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@ee1916f{r=1,c=true,a=COMPLETING,uri=//localhost:42427/D6jamcO0TJWP/,age=6} action COMPLETE
17:08:51.204 [etp939291483-36] DEBUG org.eclipse.jetty.server.HttpChannel - sendResponse info=null content=HeapByteBuffer@2567b617[p=0,l=0,c=0,r=0]={<<<>>>} complete=true committing=false callback=Blocker@57203108{null}
17:08:51.205 [etp939291483-36] DEBUG org.eclipse.jetty.server.HttpChannel - COMPLETE for /D6jamcO0TJWP/ written=317
17:08:51.207 [etp939291483-36] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@ee1916f{r=1,c=true,a=COMPLETED,uri=//localhost:42427/D6jamcO0TJWP/,age=9} onContent Content@69781bf9{HeapByteBufferR@60a6bb36[p=236,l=382,c=8192,r=146]={PROPFIND /D6jamcO...gvfs/1.36.1\r\n\r\n<<<<?xml version="1....\n </D:propfind>>>>ropfind>\x00\x00\x00\x00\x00\x00\x00\x00\x00...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00}}
17:08:51.212 [Background Thread 2] DEBUG o.c.f.webdav.mount.LinuxGioMounter - Mounted dav://localhost:42427/D6jamcO0TJWP/DataBox
17:08:51.212 [etp939291483-36] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@ee1916f{r=1,c=true,a=COMPLETED,uri=//localhost:42427/D6jamcO0TJWP/,age=11} onContentComplete
17:08:51.214 [etp939291483-36] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@ee1916f{r=1,c=true,a=COMPLETED,uri=//localhost:42427/D6jamcO0TJWP/,age=17} onRequestComplete
17:08:51.215 [etp939291483-36] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@ee1916f{r=1,c=false,a=IDLE,uri=null,age=0} handle exit, result COMPLETE
17:08:51.427 [etp939291483-43] DEBUG org.eclipse.jetty.server.HttpChannel - REQUEST for //localhost:42427/D6jamcO0TJWP/DataBox on HttpChannelOverHttp@ee1916f{r=2,c=false,a=IDLE,uri=//localhost:42427/D6jamcO0TJWP/DataBox,age=0}
PROPFIND //localhost:42427/D6jamcO0TJWP/DataBox HTTP/1.1
Depth: 0
Apply-To-Redirect-Ref: T
Content-Length: 235
17:08:51.427 [etp939291483-43] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@ee1916f{r=2,c=false,a=IDLE,uri=//localhost:42427/D6jamcO0TJWP/DataBox,age=0} handle //localhost:42427/D6jamcO0TJWP/DataBox
17:08:51.428 [etp939291483-43] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@ee1916f{r=2,c=false,a=DISPATCHED,uri=//localhost:42427/D6jamcO0TJWP/DataBox,age=0} action DISPATCH
17:08:51.432 [etp939291483-43] DEBUG org.eclipse.jetty.server.HttpChannel - sendResponse info=null content=HeapByteBuffer@2567b617[p=0,l=0,c=0,r=0]={<<<>>>} complete=true committing=true callback=Blocker@57203108{null}
17:08:51.433 [etp939291483-43] DEBUG org.eclipse.jetty.server.HttpChannel - COMMIT for /D6jamcO0TJWP/DataBox on HttpChannelOverHttp@ee1916f{r=2,c=true,a=DISPATCHED,uri=//localhost:42427/D6jamcO0TJWP/DataBox,age=6}
302 null HTTP/1.1
17:08:51.439 [etp939291483-43] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@ee1916f{r=2,c=true,a=COMPLETING,uri=//localhost:42427/D6jamcO0TJWP/DataBox,age=11} action COMPLETE
17:08:51.439 [etp939291483-43] DEBUG org.eclipse.jetty.server.HttpChannel - COMPLETE for /D6jamcO0TJWP/DataBox written=0
17:08:51.439 [etp939291483-43] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@ee1916f{r=2,c=true,a=COMPLETED,uri=//localhost:42427/D6jamcO0TJWP/DataBox,age=12} onContent Content@58b2b737{HeapByteBufferR@5c8d38f9[p=269,l=504,c=8192,r=235]={PROPFIND /D6jamcO...Length: 235\r\n\r\n<<<<?xml version="1....\n </D:propfind>>>>\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00}}
17:08:51.440 [etp939291483-43] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@ee1916f{r=2,c=true,a=COMPLETED,uri=//localhost:42427/D6jamcO0TJWP/DataBox,age=13} onContentComplete
17:08:51.440 [etp939291483-43] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@ee1916f{r=2,c=true,a=COMPLETED,uri=//localhost:42427/D6jamcO0TJWP/DataBox,age=13} onRequestComplete
17:08:51.440 [etp939291483-43] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@ee1916f{r=2,c=false,a=IDLE,uri=null,age=0} handle exit, result COMPLETE
17:08:51.441 [etp939291483-43] DEBUG org.eclipse.jetty.server.HttpChannel - REQUEST for //localhost:42427/D6jamcO0TJWP/DataBox/ on HttpChannelOverHttp@ee1916f{r=3,c=false,a=IDLE,uri=//localhost:42427/D6jamcO0TJWP/DataBox/,age=0}
Depth: 0
Content-Length: 235
17:08:51.441 [etp939291483-43] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@ee1916f{r=3,c=false,a=IDLE,uri=//localhost:42427/D6jamcO0TJWP/DataBox/,age=0} handle //localhost:42427/D6jamcO0TJWP/DataBox/
17:08:51.442 [etp939291483-43] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@ee1916f{r=3,c=false,a=DISPATCHED,uri=//localhost:42427/D6jamcO0TJWP/DataBox/,age=0} action DISPATCH
17:08:51.442 [etp939291483-43] INFO o.c.w.core.filters.LoggingFilter - REQUEST 2:
Content-Length: 235
Depth: 0
17:08:52.054 [etp939291483-43] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@ee1916f{r=3,c=false,a=DISPATCHED,uri=//localhost:42427/D6jamcO0TJWP/DataBox/,age=612} onContent Content@651a4caf{HeapByteBufferR@28dc4434[p=270,l=505,c=8192,r=235]={PROPFIND /D6jamcO...gvfs/1.36.1\r\n\r\n<<<<?xml version="1....\n </D:propfind>>>>\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00}}
17:08:52.054 [etp939291483-43] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@ee1916f{r=3,c=false,a=DISPATCHED,uri=//localhost:42427/D6jamcO0TJWP/DataBox/,age=613} onContentComplete
17:08:52.055 [etp939291483-43] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@ee1916f{r=3,c=false,a=DISPATCHED,uri=//localhost:42427/D6jamcO0TJWP/DataBox/,age=613} onRequestComplete
17:08:52.067 [etp939291483-43] DEBUG org.eclipse.jetty.server.HttpChannel - sendResponse info=null content=HeapByteBuffer@61eeb4fe[p=0,l=595,c=595,r=595]={<<<<?xml version="1..../D:multistatus>>>>} complete=true committing=true callback=Blocker@57203108{null}
17:08:52.068 [etp939291483-43] DEBUG org.eclipse.jetty.server.HttpChannel - COMMIT for /D6jamcO0TJWP/DataBox/ on HttpChannelOverHttp@ee1916f{r=3,c=true,a=DISPATCHED,uri=//localhost:42427/D6jamcO0TJWP/DataBox/,age=626}
207 null HTTP/1.1
Content-Length: 595
17:08:52.068 [etp939291483-43] INFO o.c.w.core.filters.LoggingFilter - RESPONSE 2:
207
Content-Length: 595
17:08:52.069 [etp939291483-43] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@ee1916f{r=3,c=true,a=COMPLETING,uri=//localhost:42427/D6jamcO0TJWP/DataBox/,age=627} action COMPLETE
17:08:52.069 [etp939291483-43] DEBUG org.eclipse.jetty.server.HttpChannel - COMPLETE for /D6jamcO0TJWP/DataBox/ written=595
17:08:52.069 [etp939291483-43] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@ee1916f{r=3,c=false,a=IDLE,uri=null,age=0} handle exit, result COMPLETE
17:08:52.072 [etp939291483-47] DEBUG org.eclipse.jetty.server.HttpChannel - REQUEST for //localhost:42427/D6jamcO0TJWP/DataBox on HttpChannelOverHttp@ee1916f{r=4,c=false,a=IDLE,uri=//localhost:42427/D6jamcO0TJWP/DataBox,age=0}
Depth: 0
Content-Length: 235
17:08:52.073 [etp939291483-47] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@ee1916f{r=4,c=false,a=IDLE,uri=//localhost:42427/D6jamcO0TJWP/DataBox,age=1} handle //localhost:42427/D6jamcO0TJWP/DataBox
17:08:52.073 [etp939291483-47] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@ee1916f{r=4,c=false,a=DISPATCHED,uri=//localhost:42427/D6jamcO0TJWP/DataBox,age=1} action DISPATCH
17:08:52.073 [etp939291483-47] DEBUG org.eclipse.jetty.server.HttpChannel - sendResponse info=null content=HeapByteBuffer@2567b617[p=0,l=0,c=0,r=0]={<<<>>>} complete=true committing=true callback=Blocker@57203108{null}
17:08:52.073 [etp939291483-47] DEBUG org.eclipse.jetty.server.HttpChannel - COMMIT for /D6jamcO0TJWP/DataBox on HttpChannelOverHttp@ee1916f{r=4,c=true,a=DISPATCHED,uri=//localhost:42427/D6jamcO0TJWP/DataBox,age=1}
302 null HTTP/1.1
Date: Sun, 27 Jan 2019 16:08:52 GMT
17:08:52.074 [etp939291483-47] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@ee1916f{r=4,c=true,a=COMPLETING,uri=//localhost:42427/D6jamcO0TJWP/DataBox,age=2} action COMPLETE
17:08:52.075 [etp939291483-47] DEBUG org.eclipse.jetty.server.HttpChannel - COMPLETE for /D6jamcO0TJWP/DataBox written=0
17:08:52.075 [etp939291483-47] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@ee1916f{r=4,c=true,a=COMPLETED,uri=//localhost:42427/D6jamcO0TJWP/DataBox,age=3} onContent Content@57bfffc6{HeapByteBufferR@59780b41[p=269,l=504,c=8192,r=235]={PROPFIND /D6jamcO...Length: 235\r\n\r\n<<<<?xml version="1....\n </D:propfind>>>>>\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00}}
17:08:52.075 [etp939291483-47] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@ee1916f{r=4,c=true,a=COMPLETED,uri=//localhost:42427/D6jamcO0TJWP/DataBox,age=3} onContentComplete
17:08:52.075 [etp939291483-47] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@ee1916f{r=4,c=true,a=COMPLETED,uri=//localhost:42427/D6jamcO0TJWP/DataBox,age=3} onRequestComplete
17:08:52.076 [etp939291483-47] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@ee1916f{r=4,c=false,a=IDLE,uri=null,age=0} handle exit, result COMPLETE
17:08:52.076 [etp939291483-47] DEBUG org.eclipse.jetty.server.HttpChannel - REQUEST for //localhost:42427/D6jamcO0TJWP/DataBox/ on HttpChannelOverHttp@ee1916f{r=5,c=false,a=IDLE,uri=//localhost:42427/D6jamcO0TJWP/DataBox/,age=0}
Depth: 0
Content-Length: 235
17:08:52.077 [etp939291483-47] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@ee1916f{r=5,c=false,a=IDLE,uri=//localhost:42427/D6jamcO0TJWP/DataBox/,age=1} handle //localhost:42427/D6jamcO0TJWP/DataBox/
17:08:52.077 [etp939291483-47] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@ee1916f{r=5,c=false,a=DISPATCHED,uri=//localhost:42427/D6jamcO0TJWP/DataBox/,age=1} action DISPATCH
17:08:52.078 [etp939291483-47] INFO o.c.w.core.filters.LoggingFilter - REQUEST 3:
Content-Length: 235
Depth: 0
17:08:52.155 [etp939291483-47] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@ee1916f{r=5,c=false,a=DISPATCHED,uri=//localhost:42427/D6jamcO0TJWP/DataBox/,age=79} onContent Content@1845017a{HeapByteBufferR@30ac9c7b[p=270,l=505,c=8192,r=235]={PROPFIND /D6jamcO...gvfs/1.36.1\r\n\r\n<<<<?xml version="1....\n </D:propfind>>>>\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00}}
17:08:52.155 [etp939291483-47] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@ee1916f{r=5,c=false,a=DISPATCHED,uri=//localhost:42427/D6jamcO0TJWP/DataBox/,age=79} onContentComplete
17:08:52.156 [etp939291483-47] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@ee1916f{r=5,c=false,a=DISPATCHED,uri=//localhost:42427/D6jamcO0TJWP/DataBox/,age=80} onRequestComplete
17:08:52.160 [etp939291483-47] DEBUG org.eclipse.jetty.server.HttpChannel - sendResponse info=null content=HeapByteBuffer@2997bb2c[p=0,l=595,c=595,r=595]={<<<<?xml version="1..../D:multistatus>>>>} complete=true committing=true callback=Blocker@57203108{null}
17:08:52.165 [etp939291483-47] DEBUG org.eclipse.jetty.server.HttpChannel - COMMIT for /D6jamcO0TJWP/DataBox/ on HttpChannelOverHttp@ee1916f{r=5,c=true,a=DISPATCHED,uri=//localhost:42427/D6jamcO0TJWP/DataBox/,age=89}
207 null HTTP/1.1
Content-Length: 595
17:08:52.166 [etp939291483-47] INFO o.c.w.core.filters.LoggingFilter - RESPONSE 3:
207
Content-Length: 595
Please help.
Thank you!
