I use cryptomator unter ubuntu 20.04.
Linux-Kernel: 5.13.0-40-generic (hwe)
In the decrypted vault there is one file listed with ls:
?????????? ? ? ? ? ? info
I cannot delete this file, rename it or anything else. I tried all ways (chmod, trying to delete with inum,…) I found on the internet to delete these questionmark-files but I simply get a
rm: cannot remove 'info': No such file or directory
I had such a problem with a vault some time ago. I cost me a lot of time to find out that I even had such questionmark-files. I had to restore a backup and the only way was to create a new vautl. I made sure there were none of these files in the new vault.
Also nowhere on my usual filesystems I find such ???-files, so I don’t think that my filesystems or even the device is corrupted.
But now, with the new vault, another of these files has appeared, which was not in the backup.
I think there is an issue with the filesystem of the vault. It is mounted as
fusefs1457252166 on /home/hugo/vaults/my-vault type fuse.fusefs1457252166 (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
I ran a healthcheck on the vault (selected all options) and the result shows one error with the Resource Type Checks. One file is listed as
Node /home/... of unknown type.
Can/should I delete this file in the vault or do you have any other suggestions.
Thank you in advance,
Hugo
