Hello community!
When i try to open my vault …
i see this error:
org.cryptomator.common.vaults.Volume$VolumeException: Did not find feasible mount point.
at org.cryptomator.common.vaults.FuseVolume.chooseNonExistingTemporaryMountPoint(FuseVolume.java:96)
at org.cryptomator.common.vaults.FuseVolume.prepareTemporaryMountPoint(FuseVolume.java:73)
at org.cryptomator.common.vaults.FuseVolume.mount(FuseVolume.java:55)
somebody know the correct steps to fix this,
thanks!
