I just installed Crypto and am trying to unlock the vault for the first time since creating the password. I am on a Mac. When I put the password in, it gives the following error message and says that it’s already unlocked, but it still says its locked. Please help. I appreciate your time. Thank you.
java.lang.IllegalStateException: Already unlocked.
at org.cryptomator.common.vaults.Vault.unlock(Vault.java:131)
