Hello. I cant unlock my accunt! I put my password but i get this error:
OS: Windows Server 2022 / 10.0
App: 1.6.17 / msi-4104
Error Code V18O:SBOR:KOHR
org.cryptomator.common.vaults.Volume$VolumeException: org.cryptomator.frontend.webdav.mount.Mounter$CommandFailedException: Command failed with exit code 2. Expected 0. Stderr: System error 67 has occurred.
The network name cannot be found.
at org.cryptomator.desktop@1.6.17/org.cryptomator.common.vaults.WebDavVolume.mountServlet(WebDavVolume.java:87)
at org.cryptomator.desktop@1.6.17/org.cryptomator.common.vaults.WebDavVolume.mount(WebDavVolume.java:49)
at org.cryptomator.desktop@1.6.17/org.cryptomator.common.vaults.Vault.unlock(Vault.java:154)
at org.cryptomator.desktop@1.6.17/org.cryptomator.ui.keyloading.KeyLoadingStrategy.use(KeyLoadingStrategy.java:79)
at org.cryptomator.desktop@1.6.17/org.cryptomator.ui.unlock.UnlockWorkflow.attemptUnlock(UnlockWorkflow.java:72)
at org.cryptomator.desktop@1.6.17/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:62)
at org.cryptomator.desktop@1.6.17/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:35)
Caused by: org.cryptomator.frontend.webdav.mount.Mounter$CommandFailedException: Command failed with exit code 2. Expected 0. Stderr: System error 67 has occurred.
at org.cryptomator.frontend.webdav@1.2.8/org.cryptomator.frontend.webdav.mount.ProcessUtil.assertExitValue(ProcessUtil.java:28)
at org.cryptomator.frontend.webdav@1.2.8/org.cryptomator.frontend.webdav.mount.WindowsMounter.mount(WindowsMounter.java:43)
at org.cryptomator.frontend.webdav@1.2.8/org.cryptomator.frontend.webdav.servlet.WebDavServletController.mount(WebDavServletController.java:102)
at org.cryptomator.desktop@1.6.17/org.cryptomator.common.vaults.WebDavVolume.mountServlet(WebDavVolume.java:85)
... 12 more
