When I try to mount my vault with cryptomator v1.3.2 on Debian Jessie amd64. I get:
08:59:15.733 [pool-3-thread-2] INFO org.cryptomator.frontend.webdav.servlet.WebDavServletController - WebDavServlet started: /7CPTV5OES4O6/VAULT_mator
08:59:15.839 [pool-3-thread-2] INFO org.cryptomator.frontend.webdav.servlet.WebDavServletController - Mounting http://localhost:42427/7CPTV5OES4O6/VAULT_mator using org.cryptomator.frontend.webdav.mount.Lin
uxGvfsMounter
08:59:15.845 [JavaFX Application Thread] ERROR org.cryptomator.ui.controllers.UnlockedController - Mount failed.
org.cryptomator.frontend.webdav.mount.Mounter$CommandFailedException: Command failed with exit code 2. Expected 0. Stderr: Error mounting location: volume doesn’t implement mount
at org.cryptomator.frontend.webdav.mount.LinuxGvfsMounter.mount(LinuxGvfsMounter.java:39)
at org.cryptomator.ui.model.Vault.mount(Vault.java:140)
at org.cryptomator.ui.controllers.UnlockedController.lambda$mountVault$1(UnlockedController.java:164)
mount http://localhost:42427/7CPTV5OES4O6/VAULT_mator ~/VAULT/
mount: only root can do that
As noted, the mount command is successful as root and I can access the files within.
What can I do?
