Hello, I am getting the following error when trying to open the vault using Dokany:
Caused by: org.cryptomator.frontend.dokany.DokanyMountFailedException: Unable to parse mount options
at org.cryptomator.frontend.dokany.MountFactory.parseMountOptions(MountFactory.java:140)
at org.cryptomator.frontend.dokany.MountFactory.mount(MountFactory.java:108)
... 11 more
Caused by: org.apache.commons.cli.UnrecognizedOptionException: Unrecognized option: -ouid=-1
at org.apache.commons.cli.DefaultParser.handleUnknownToken(DefaultParser.java:360)
at org.apache.commons.cli.DefaultParser.handleLongOptionWithEqual(DefaultParser.java:440)
at org.apache.commons.cli.DefaultParser.handleShortAndLongOption(DefaultParser.java:569)
at org.apache.commons.cli.DefaultParser.handleToken(DefaultParser.java:243)
at org.apache.commons.cli.DefaultParser.parse(DefaultParser.java:120)
at org.apache.commons.cli.DefaultParser.parse(DefaultParser.java:76)
at org.apache.commons.cli.DefaultParser.parse(DefaultParser.java:60)
at org.cryptomator.frontend.dokany.MountUtil.parse(MountUtil.java:152)
at org.cryptomator.frontend.dokany.MountFactory.parseMountOptions(MountFactory.java:138)
... 13 more
What could be the problem and how to solve it?
I am using Cryptomator 1.5.16
