Installed [Cryptomator-1.3.4-x64.exe]
The first time I tried to use it, I got:
22:38:30.071 [main] INFO org.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.3.4 on Windows 7 6.1 (amd64)
22:38:30.697 [JavaFX Application Thread] INFO o.c.launcher.MainApplication - JavaFX application started.
22:38:30.787 [JavaFX Application Thread] INFO o.c.common.settings.SettingsProvider - Failed to load settings, creating new one.
22:38:31.172 [JavaFX Application Thread] INFO org.cryptomator.jni.JniModule - loaded WinFunctions.dll
22:38:31.881 [pool-4-thread-1] INFO o.a.http.impl.execchain.RetryExec - I/O exception (java.net.SocketException) caught when processing request to {s}->https_api_cryptomator_org:443: Permission denied: connect
22:38:31.882 [pool-4-thread-1] INFO o.a.http.impl.execchain.RetryExec - Retrying request to {s}->https_api_cryptomator_org:443
22:38:31.884 [pool-4-thread-1] INFO o.a.http.impl.execchain.RetryExec - I/O exception (java.net.SocketException) caught when processing request to {s}->https_api_cryptomator_org:443: Permission denied: connect
22:38:31.884 [pool-4-thread-1] INFO o.a.http.impl.execchain.RetryExec - Retrying request to {s}->https_api_cryptomator_org:443
22:38:31.885 [pool-4-thread-1] INFO o.a.http.impl.execchain.RetryExec - I/O exception (java.net.SocketException) caught when processing request to {s}->https_api_cryptomator_org:443: Permission denied: connect
22:38:31.886 [pool-4-thread-1] INFO o.a.http.impl.execchain.RetryExec - Retrying request to {s}->https_api_cryptomator_org:443
22:38:32.625 [JavaFX Application Thread] ERROR o.c.ui.util.AsyncTaskService - Uncaught exception
java.net.SocketException: Permission denied: connect
at java.net.DualStackPlainSocketImpl.waitForConnect(Native Method)
at java.net.DualStackPlainSocketImpl.socketConnect(DualStackPlainSocketImpl.java:85)
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
at java.net.Socket.connect(Socket.java:589)
at org.apache.http.conn.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:339)
at org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:142)
at org.apache.http.impl.conn.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:359)
at org.apache.http.impl.execchain.MainClientExec.establishRoute(MainClientExec.java:381)
at org.apache.http.impl.execchain.MainClientExec.execute(MainClientExec.java:237)
at org.apache.http.impl.execchain.ProtocolExec.execute(ProtocolExec.java:185)
at org.apache.http.impl.execchain.RetryExec.execute(RetryExec.java:89)
at org.apache.http.impl.execchain.RedirectExec.execute(RedirectExec.java:111)
at org.apache.http.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:185)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:83)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:108)
at org.cryptomator.ui.controllers.WelcomeController.lambda$checkForUpdates$0(WelcomeController.java:130)
22:39:08.276 [JavaFX Application Thread] INFO org.eclipse.jetty.util.log - Logging initialized @-1ms to org.eclipse.jetty.util.log.Slf4jLog
22:39:08.325 [JavaFX Application Thread] INFO o.c.frontend.webdav.WebDavServer - Binding server socket to 127.0.0.1:42427
22:39:08.344 [JavaFX Application Thread] INFO o.e.jetty.server.AbstractConnector - Started ServerConnector@31441844{HTTP/1.1,[http/1.1]}{127.0.0.1:42427}
22:39:09.356 [pool-3-thread-1] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\bill\AppData\Roaming\Cryptomator\settings.json
22:39:22.964 [JavaFX Application Thread] INFO o.c.k.WindowsProtectedKeychainAccess - Creating new keychain at path C:\Users\bill\AppData\Roaming\Cryptomator\keychain.json
22:39:32.250 [pool-4-thread-2] INFO org.eclipse.jetty.server.Server - jetty-9.4.8.v20171121, build timestamp: 2017-11-21T16:27:37-05:00, git hash: 82b8fb23f757335bb3329d540ce37a2a2615f0a8
22:39:32.289 [pool-4-thread-2] INFO o.e.j.server.handler.ContextHandler - Started o.e.j.s.ServletContextHandler@e574eb2{/,null,AVAILABLE}
22:39:32.289 [pool-4-thread-2] INFO org.eclipse.jetty.server.Server - Started @-1ms
22:39:32.290 [pool-4-thread-2] INFO o.c.frontend.webdav.WebDavServer - WebDavServer started.
22:39:32.338 [pool-4-thread-2] INFO org.eclipse.jetty.server.session - DefaultSessionIdManager workerName=node0
22:39:32.339 [pool-4-thread-2] INFO org.eclipse.jetty.server.session - No SessionScavenger set, using defaults
22:39:32.340 [pool-4-thread-2] INFO org.eclipse.jetty.server.session - Scavenging every 600000ms
22:39:32.347 [pool-4-thread-2] INFO o.a.j.w.server.AbstractWebdavServlet - authenticate-header = Basic realm="Jackrabbit Webdav Server"
22:39:32.349 [pool-4-thread-2] INFO o.a.j.w.server.AbstractWebdavServlet - csrf-protection = null
22:39:32.349 [pool-4-thread-2] INFO o.a.j.w.server.AbstractWebdavServlet - createAbsoluteURI = true
22:39:32.349 [pool-4-thread-2] INFO o.e.j.server.handler.ContextHandler - Started o.e.j.s.ServletContextHandler@66ed124d{/vN-PnfdmRIQo/s,null,AVAILABLE}
22:39:32.350 [pool-4-thread-2] INFO o.c.f.w.s.WebDavServletController - WebDavServlet started: /vN-PnfdmRIQo/s
22:39:32.431 [pool-4-thread-2] INFO o.c.f.w.s.WebDavServletController - Mounting http://cryptomator-vault:42427/vN-PnfdmRIQo/s using org.cryptomator.frontend.webdav.mount.WindowsMounter
22:39:32.606 [JavaFX Application Thread] ERROR o.c.u.controllers.UnlockedController - Mount failed.
org.cryptomator.frontend.webdav.mount.Mounter$CommandFailedException: Command failed with exit code 2. Expected 0. Stderr: System error 67 has occurred.
The network name cannot be found.
at org.cryptomator.ui.model.Vault.mount(Vault.java:140)
at org.cryptomator.ui.controllers.UnlockedController.lambda$mountVault$1(UnlockedController.java:164)
22:41:39.625 [pool-3-thread-1] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\bill\AppData\Roaming\Cryptomator\settings.json
22:51:42.435 [JavaFX Application Thread] INFO o.e.j.server.handler.ContextHandler - Stopped o.e.j.s.ServletContextHandler@66ed124d{/vN-PnfdmRIQo/s,null,UNAVAILABLE}
22:51:42.436 [JavaFX Application Thread] INFO o.c.f.w.s.WebDavServletController - WebDavServlet stopped: /vN-PnfdmRIQo/s
22:51:42.454 [JavaFX Application Thread] INFO o.c.launcher.MainApplication - JavaFX application stopped.
22:51:42.457 [Thread-1] INFO o.c.launcher.CleanShutdownPerformer - Goodbye.
