Hello. First post here. I am using Macos 10.13.6 Sierra (yeah, I know, old) and Cryptomator 1.5.19. On trying to access my vaults (2 on different external HDDs), the error message pasted appears.
The vaults were created using a different computer, same OS version, unrecorded Cryptomator version. That computer crashed and is dead now. I was beginning to test this app to then upload my files to a cloud backup service when my main computer died. My secondary laptop is working fine, but I have no access to my vaults. Some important files there.
Any help is appreciated.
Thanks
org.cryptomator.cryptolib.api.UnsupportedVaultFormatException: Tried to open vault of version 999, but can only handle version 7
at org.cryptomator.cryptolib.v1.CryptorProviderImpl.createFromKeyFile(CryptorProviderImpl.java:117)
at org.cryptomator.cryptolib.v1.CryptorProviderImpl.createFromKeyFile(CryptorProviderImpl.java:108)
at org.cryptomator.cryptolib.v1.CryptorProviderImpl.createFromKeyFile(CryptorProviderImpl.java:40)
at org.cryptomator.cryptofs.CryptoFileSystemModule.provideCryptor(CryptoFileSystemModule.java:41)
at org.cryptomator.cryptofs.CryptoFileSystemModule_ProvideCryptorFactory.provideCryptor(CryptoFileSystemModule_ProvideCryptorFactory.java:56)
at org.cryptomator.cryptofs.CryptoFileSystemModule_ProvideCryptorFactory.get(CryptoFileSystemModule_ProvideCryptorFactory.java:43)
at org.cryptomator.cryptofs.DaggerCryptoFileSystemProviderComponent$CryptoFileSystemComponentImpl.cryptoFileSystem(DaggerCryptoFileSystemProviderComponent.java:337)
at org.cryptomator.common.vaults.Vault.createCryptoFileSystem(Vault.java:130)
at org.cryptomator.common.vaults.Vault.unlock(Vault.java:147)
