After setting up my Vaults I am getting the following error.
This is my first installation on macOS Catalina.
I am saving the files in a directory using APFS Encrypted disc partition.
Any help will be appreciated.
Thanks in advance.
Error Code RK30:3502:8HI8
at org.cryptomator.desktop@1.6.13/org.cryptomator.common.vaults.FuseVolume.mount(FuseVolume.java:58)
at org.cryptomator.desktop@1.6.13/org.cryptomator.common.vaults.FuseVolume.mount(FuseVolume.java:45)
at org.cryptomator.desktop@1.6.13/org.cryptomator.common.vaults.Vault.unlock(Vault.java:155)
at org.cryptomator.desktop@1.6.13/org.cryptomator.ui.keyloading.KeyLoadingStrategy.use(KeyLoadingStrategy.java:79)
at org.cryptomator.desktop@1.6.13/org.cryptomator.ui.unlock.UnlockWorkflow.attemptUnlock(UnlockWorkflow.java:72)
at org.cryptomator.desktop@1.6.13/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:62)
at org.cryptomator.desktop@1.6.13/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:35)
at javafx.graphics@18.0.1/javafx.concurrent.Task$TaskCallable.call(Task.java:1426)
Caused by: org.cryptomator.frontend.fuse.mount.FuseMountException: java.util.concurrent.TimeoutException: fuse init() not called after 10000 milliseconds.
at org.cryptomator.frontend.fuse@1.3.4/org.cryptomator.frontend.fuse.mount.AbstractMounter.mount(AbstractMounter.java:48)
at org.cryptomator.frontend.fuse@1.3.4/org.cryptomator.frontend.fuse.mount.Mounter.mount(Mounter.java:15)
at org.cryptomator.desktop@1.6.13/org.cryptomator.common.vaults.FuseVolume.mount(FuseVolume.java:56)
... 12 more
Caused by: java.util.concurrent.TimeoutException: fuse init() not called after 10000 milliseconds.
at org.cryptomator.frontend.fuse@1.3.4/org.cryptomator.frontend.fuse.ReadOnlyAdapter.awaitInitCall(ReadOnlyAdapter.java:290)
at org.cryptomator.frontend.fuse@1.3.4/org.cryptomator.frontend.fuse.mount.AbstractMounter.mount(AbstractMounter.java:39)
... 14 more
