im working under linux mint and getting the E5BN:E5BN:BIEF error when trying to unlock a shred directory. The solution proposed for this here is to change FUSE to WebDAV in the settings. Done that, I get the error V18O:1EHT:D5ID while unlocking, which apparently can be resolved by… changing WebDAV back to FUSE.
Im kinda stuck there, can somebody assist me please?
That is strange. You are the first who reports this error and uses a linux-based OS.
Selecting FUSE means, that for system integration the fuse-library should be used. This library is nearly always present on linux systems, but you can check if it is installed. Additionally, did you chose a specific mountpoint? If so, try to change the option to let Cryptomator pick the mountpoint.
