Hello, I’m using Cryptomator 1.4.15 on Windows 10.
The default volume Dokany performs extremely poorly compared to WebDAV. Copying a 1GB zip file to a Dokany-mounted volume takes over half an hour to complete while doing the same with WebDAV takes around one minute.
Is this a known issue?
If so, are there any downsides, security-wise, to using WebDAV for now while I wait for a fix?
Thanks in advance!
Yes, see Very slow writing, normal reading · Issue #960 · cryptomator/cryptomator · GitHub. The speed of the Dokany adapter depends differs on the user system. On my setup i do not have any problem, but we had several reports
No.
