I wish I had had the presence of mind to take better notes.
I’m running a vault (using latest CM) that is sourced from an external drive running exFat. Yesterday I went to synch the fault files with Google Drive using Rclone. To my surprise, pretty much all the files in the vault needed to have their datestamp updated (I should have counted – thus my comment about notes). This was puzzling, since I hadn’t done anything to the files to change them. Being impatient I went ahead and ran the process, which took somewhere around 2 hours.
Thinking about it, I realized that we changed out of daylight savings time over the weekend. The exFat format stores the time and the timezone information separately. I’m thinking that it is possible that the vault files were saved without the timezone info. Of course, it could also be Rclone doesn’t know how to use timezone info when doing comparisons. It could even be that Google drive doesn’t store the date stamp correctly. Or stores it differently. It’s a many-headed hydra, but I thought I would start by asking here if anyone happens to know about CM and exFat.
Thanks!
