If I have my VPN running, I am unable to open vaults. If I close the VPN, then vaults open with no problem.
Below is the error I get, after the long time out and spinning dialog, when the VPN is running and I try to open any of my vaults:
Error Code OCA2:QSHH:0GR3
org.cryptomator.common.vaults.Volume$VolumeException: org.cryptomator.frontend.webdav.mount.ProcessUtil$CommandTimeoutException: Command timed out.
at org.cryptomator.desktop@1.6.17/org.cryptomator.common.vaults.WebDavVolume.mountServlet(WebDavVolume.java:87)
at org.cryptomator.desktop@1.6.17/org.cryptomator.common.vaults.WebDavVolume.mount(WebDavVolume.java:49)
at org.cryptomator.desktop@1.6.17/org.cryptomator.common.vaults.Vault.unlock(Vault.java:154)
at org.cryptomator.desktop@1.6.17/org.cryptomator.ui.keyloading.KeyLoadingStrategy.use(KeyLoadingStrategy.java:79)
at org.cryptomator.desktop@1.6.17/org.cryptomator.ui.unlock.UnlockWorkflow.attemptUnlock(UnlockWorkflow.java:72)
at org.cryptomator.desktop@1.6.17/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:62)
at org.cryptomator.desktop@1.6.17/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:35)
Caused by: org.cryptomator.frontend.webdav.mount.ProcessUtil$CommandTimeoutException: Command timed out.
at org.cryptomator.frontend.webdav@1.2.8/org.cryptomator.frontend.webdav.mount.ProcessUtil.waitFor(ProcessUtil.java:68)
at org.cryptomator.frontend.webdav@1.2.8/org.cryptomator.frontend.webdav.mount.MacAppleScriptMounter.mount(MacAppleScriptMounter.java:41)
at org.cryptomator.frontend.webdav@1.2.8/org.cryptomator.frontend.webdav.servlet.WebDavServletController.mount(WebDavServletController.java:102)
at org.cryptomator.desktop@1.6.17/org.cryptomator.common.vaults.WebDavVolume.mountServlet(WebDavVolume.java:85)
... 12 more
