Using the latest Windows 10 Fall Creators Update. Version 1709 OS Build 16299.19. Cryptomator will open a vault from a different location but not from OneDrive. Have made sure the file in OneDrive has been downloaded and is in on the system. I am able to create a vault within OneDrive though. Everything used to work perfectly before the Fall Update.
The log says the path to OneDrive is invalid.
Here is the log file:
18:42:45.587 [main] INFO org.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.3.1 on Windows 10 10.0 (amd64)
18:42:47.276 [JavaFX Application Thread] INFO o.c.launcher.MainApplication - JavaFX application started.
18:42:47.380 [JavaFX Application Thread] INFO o.c.common.settings.SettingsProvider - Settings loaded from C:\Users\abc\AppData\Roaming\Cryptomator\settings.json
18:42:47.381 [JavaFX Application Thread] DEBUG org.cryptomator.logging.DebugMode - Debug mode initialized
18:42:47.387 [JavaFX Application Thread] DEBUG org.cryptomator.ui.l10n.Localization - Loaded localization default file: /localization/en.txt
18:42:47.412 [JavaFX Application Thread] DEBUG org.cryptomator.ui.l10n.Localization - Detected language "en" and region "US"
18:42:47.415 [JavaFX Application Thread] TRACE org.cryptomator.ui.l10n.Localization - Attempting to load localization from: /localization/en_US.txt
18:42:47.416 [JavaFX Application Thread] TRACE org.cryptomator.ui.l10n.Localization - Attempting to load localization from: /localization/en.txt
18:42:47.886 [JavaFX Application Thread] INFO org.cryptomator.jni.JniModule - loaded WinFunctions.dll
18:42:48.295 [pool-4-thread-1] DEBUG o.c.ui.controllers.WelcomeController - Checking for updates...
18:42:49.832 [pool-4-thread-1] INFO o.c.ui.controllers.WelcomeController - Current version: 1.3.1, lastest version: 1.3.1
18:43:00.088 [JavaFX Application Thread] WARN o.c.ui.controllers.MainController - Ignoring attempt to add vault with invalid path: C:\Users\abc\OneDrive\1234\masterkey.cryptomator
18:43:09.762 [JavaFX Application Thread] WARN o.c.ui.controllers.MainController - Ignoring attempt to add vault with invalid path: C:\Users\abc\OneDrive\12345\masterkey.cryptomator
But let’s be honest, that can only be a workaround… any plans to make “Files-on-demand” work at least if the Vault is marked as “always available”.
For all those who want to keep “Files-on-demand” functionality, you can head over to https://mountainduck.io/ and grab a copy. Just mount your vault via MountainDuck and forget the Cryptomator client.
Are there any plans to support the Files-on-demand feature? First maybe under the assumption that the whole vault is always fully available offline…? I think this should work seamlessly…
Hello. Thanks for the patch.
I have been using it and seems to see, open, rename, move etc. files and directories OK.
However I came across an issue (which I discovered by using my backup software), is that the file and directory sizes are not read (or computed) correctly. Using right-click on the file or directory. You get file sizes like -1byte for the file and -20 bytes for directories. The quantity of files and folders is correct.
I updated today to v1.3.2.
I now cannot add an existing vault from OneDrive with Files on Demand turned on. There are no error messages to send. I can add vaults stored on local drive so it appears only to effect OneDrive vaults.
The previous v1.3.1 together with patch, I could add existing vaults.
