after installing Cryptomator 1.6.1 and starting the desktop app. I can only see an empty view of the mask.
Any idea why? I do have Kaspersky Antivirus active
Thank you for your help
Doolittle
Doolittle
This Cryptomator version is quite old. Does installing the latest version (you can download it from www.cryptomator.org) fix your problem?
Thank you @infeo, happy to be here
I did the installation with Cryptomator 1.6.14-x64 and 1.6.15-x64 and got the same results as shown in the pics.
Sorry it was my mistake. I wrote the wrong version
Update 19.11.22:
it seems to me the problem is not in the app but on my PC. But where?
09:09:34.019 [main] INFO o.c.common.settings.SettingsProvider - Settings loaded from C:\Users\Admin\AppData\Roaming\Cryptomator\settings.json
09:09:34.042 [main] INFO org.cryptomator.common.Environment - user.home: C:\Users\Admin
09:09:34.043 [main] INFO org.cryptomator.common.Environment - java.library.path: C:\Program Files\Cryptomator;C:\Program Files\Cryptomator\app;.
09:09:34.043 [main] INFO org.cryptomator.common.Environment - user.language: de
09:09:34.043 [main] INFO org.cryptomator.common.Environment - user.region: null
09:09:34.043 [main] INFO org.cryptomator.common.Environment - logback.configurationFile: null
09:09:34.044 [main] INFO org.cryptomator.common.Environment - cryptomator.settingsPath: ~/AppData/Roaming/Cryptomator/settings.json
09:09:34.044 [main] INFO org.cryptomator.common.Environment - cryptomator.ipcSocketPath: ~/AppData/Roaming/Cryptomator/ipc.socket
09:09:34.044 [main] INFO org.cryptomator.common.Environment - cryptomator.integrationsWin.keychainPaths: ~/AppData/Roaming/Cryptomator/keychain.json
09:09:34.044 [main] INFO org.cryptomator.common.Environment - cryptomator.logDir: ~/AppData/Roaming/Cryptomator
09:09:34.044 [main] INFO org.cryptomator.common.Environment - cryptomator.pluginDir: ~/AppData/Roaming/Cryptomator/Plugins
09:09:34.044 [main] INFO org.cryptomator.common.Environment - cryptomator.mountPointsDir: ~/Cryptomator
09:09:34.044 [main] INFO org.cryptomator.common.Environment - cryptomator.minPwLength: null
09:09:34.045 [main] INFO org.cryptomator.common.Environment - cryptomator.appVersion: 1.6.15
09:09:34.045 [main] INFO org.cryptomator.common.Environment - cryptomator.buildNumber: msi-3983
09:09:34.045 [main] INFO org.cryptomator.common.Environment - cryptomator.showTrayIcon: true
09:09:34.045 [main] INFO org.cryptomator.common.Environment - cryptomator.p12Path: ~/AppData/Roaming/Cryptomator/key.p12
09:09:34.045 [main] INFO o.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.6.15 on Windows 10 10.0 (amd64)
09:09:34.129 [main] INFO org.cryptomator.ipc.Server - Spawning IPC server listening on socket C:\Users\Admin\AppData\Roaming\Cryptomator\ipc.socket
09:09:34.652 [JavaFX Application Thread] INFO o.cryptomator.launcher.Cryptomator - JavaFX runtime started after 982ms
09:09:55.650 [App Scheduled Executor 02] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\Admin\AppData\Roaming\Cryptomator\settings.json
09:10:03.751 [App Scheduled Executor 01] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\Admin\AppData\Roaming\Cryptomator\settings.json
09:10:10.114 [App Scheduled Executor 01] INFO o.c.common.settings.SettingsProvider - Settings saved to C:\Users\Admin\AppData\Roaming\Cryptomator\settings.json
09:10:30.035 [JavaFX Application Thread] INFO o.cryptomator.launcher.Cryptomator - JavaFX application stopped.
09:10:30.040 [main] INFO o.cryptomator.launcher.Cryptomator - UI shut down
09:10:30.043 [main] INFO o.cryptomator.launcher.Cryptomator - Exit 0
JSON Settings:
“directories”: [],
“askedForUpdateCheck”: false,
“checkForUpdatesEnabled”: false,
“startHidden”: false,
“autoCloseVaults”: false,
“port”: 42427,
“numTrayNotifications”: 3,
“preferredGvfsScheme”: “DAV”,
“debugMode”: false,
“preferredVolumeImpl”: “FUSE”,
“theme”: “LIGHT”,
“uiOrientation”: “LEFT_TO_RIGHT”,
“keychainProvider”: “org.cryptomator.windows.keychain.WindowsProtectedKeychainAccess”,
“useKeychain”: false,
“licenseKey”: “”,
“showMinimizeButton”: false,
“showTrayIcon”: true,
“windowXPosition”: 359,
“windowYPosition”: 469,
“windowWidth”: 652,
“windowHeight”: 492,
“displayConfiguration”: “displayId: 0, 1920.0x1080.0; displayId: 1, 1600.0x900.0; displayId: 2, 1920.0x1080.0;”
Below is the debug log file
10:08:34.050 [main] INFO o.c.common.settings.SettingsProvider - Settings loaded from C:\Users\Admin\AppData\Roaming\Cryptomator\settings.json
10:08:34.071 [main] INFO org.cryptomator.common.Environment - user.home: C:\Users\Admin
10:08:34.072 [main] INFO org.cryptomator.common.Environment - java.library.path: C:\Program Files\Cryptomator;C:\WINDOWS\Sun\Java\bin;C:\WINDOWS\system32;
10:08:34.072 [main] INFO org.cryptomator.common.Environment - user.language: de
10:08:34.072 [main] INFO org.cryptomator.common.Environment - user.region: null
10:08:34.073 [main] INFO org.cryptomator.common.Environment - logback.configurationFile: null
10:08:34.073 [main] INFO org.cryptomator.common.Environment - cryptomator.settingsPath: ~/AppData/Roaming/Cryptomator/settings.json
10:08:34.073 [main] INFO org.cryptomator.common.Environment - cryptomator.ipcSocketPath: ~/AppData/Roaming/Cryptomator/ipc.socket
10:08:34.073 [main] INFO org.cryptomator.common.Environment - cryptomator.integrationsWin.keychainPaths: ~/AppData/Roaming/Cryptomator/keychain.json
10:08:34.073 [main] INFO org.cryptomator.common.Environment - cryptomator.logDir: ~/AppData/Roaming/Cryptomator
10:08:34.073 [main] INFO org.cryptomator.common.Environment - cryptomator.pluginDir: ~/AppData/Roaming/Cryptomator/Plugins
10:08:34.073 [main] INFO org.cryptomator.common.Environment - cryptomator.mountPointsDir: ~/Cryptomator
10:08:34.074 [main] INFO org.cryptomator.common.Environment - cryptomator.minPwLength: null
10:08:34.074 [main] INFO org.cryptomator.common.Environment - cryptomator.appVersion: 1.6.15
10:08:34.074 [main] INFO org.cryptomator.common.Environment - cryptomator.buildNumber: msi-3983
10:08:34.074 [main] INFO org.cryptomator.common.Environment - cryptomator.showTrayIcon: true
10:08:34.074 [main] INFO org.cryptomator.common.Environment - cryptomator.p12Path: ~/AppData/Roaming/Cryptomator/key.p12
10:08:34.075 [main] INFO o.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.6.15 on Windows 10 10.0 (amd64)
10:08:34.075 [main] DEBUG org.cryptomator.logging.DebugMode - Debug mode enabled
10:08:34.076 [main] DEBUG o.c.launcher.SupportedLanguages - Using system locale
10:08:34.143 [main] INFO org.cryptomator.ipc.Server - Spawning IPC server listening on socket C:\Users\Admin\AppData\Roaming\Cryptomator\ipc.socket
10:08:34.230 [main] DEBUG o.c.launcher.IpcMessageHandler - Received launch args:
10:08:34.232 [main] DEBUG o.cryptomator.launcher.Cryptomator - Did not find running application instance. Launching GUI.…
10:08:34.641 [JavaFX Application Thread] INFO o.cryptomator.launcher.Cryptomator - JavaFX runtime started after 922ms
10:08:34.650 [JavaFX Application Thread] DEBUG o.c.i.common.ClassLoaderFactory - Found jars in cryptomator.pluginDir:
10:08:34.676 [JavaFX Application Thread] DEBUG o.cryptomator.common.CommonsModule - Starting App Scheduled Executor 01
10:08:34.677 [App Scheduled Executor 01] DEBUG o.cryptomator.common.CommonsModule - Starting App Scheduled Executor 02
10:08:34.681 [JavaFX Application Thread] DEBUG o.c.i.common.ClassLoaderFactory - Found jars in cryptomator.pluginDir:
10:08:34.682 [JavaFX Application Thread] DEBUG o.c.i.common.IntegrationsLoader - UiAppearanceProvider: Found implementation: org.cryptomator.windows.uiappearance.WinUiAppearanceProvider in jar /C:/Program%20Files/Cryptomator/app/mods/integrations-win-1.1.2.jar
10:08:34.705 [JavaFX Application Thread] DEBUG o.c.i.common.IntegrationsLoader - UiAppearanceProvider: Implementation is available: org.cryptomator.windows.uiappearance.WinUiAppearanceProvider
10:08:34.916 [JavaFX Application Thread] TRACE o.cryptomator.ui.fxapp.FxApplication - FxApplication.start()
10:08:34.993 [JavaFX Application Thread] DEBUG o.c.ui.fxapp.FxApplicationTerminator - Enabling sudden termination
10:08:34.996 [JavaFX Application Thread] DEBUG o.c.i.common.ClassLoaderFactory - Found jars in cryptomator.pluginDir:
10:08:34.998 [JavaFX Application Thread] DEBUG o.c.i.common.IntegrationsLoader - TrayMenuController: Found implementation: org.cryptomator.ui.traymenu.AwtTrayMenuController in jar /C:/Program%20Files/Cryptomator/app/mods/cryptomator-1.6.15.jar
10:08:35.005 [JavaFX Application Thread] DEBUG o.c.i.common.IntegrationsLoader - TrayMenuController: Implementation is available: org.cryptomator.ui.traymenu.AwtTrayMenuController
10:08:35.340 [JavaFX Application Thread] DEBUG o.c.u.traymenu.AwtTrayMenuController - initialized tray icon
10:08:35.353 [JavaFX Application Thread] DEBUG o.cryptomator.common.CommonsModule - Starting App Background Thread 001
10:08:35.984 [JavaFX Application Thread] DEBUG o.cryptomator.ui.common.FontLoader - Loaded family: Font Awesome 5 Free Solid
10:08:36.018 [JavaFX Application Thread] TRACE o.c.u.m.MainWindowTitleController - init MainWindowTitleController
10:08:36.050 [JavaFX Application Thread] DEBUG o.c.i.common.ClassLoaderFactory - Found jars in cryptomator.pluginDir:
10:08:36.053 [JavaFX Application Thread] DEBUG o.c.i.common.IntegrationsLoader - KeychainAccessProvider: Found implementation: org.cryptomator.windows.keychain.WindowsProtectedKeychainAccess in jar /C:/Program%20Files/Cryptomator/app/mods/integrations-win-1.1.2.jar
10:08:36.062 [JavaFX Application Thread] DEBUG o.c.i.common.IntegrationsLoader - KeychainAccessProvider: Implementation is available: org.cryptomator.windows.keychain.WindowsProtectedKeychainAccess
10:08:36.310 [JavaFX Application Thread] TRACE o.c.ui.mainwindow.ResizeController - init ResizeController
10:08:36.316 [JavaFX Application Thread] TRACE o.c.u.m.MainWindowController - init MainWindowController
10:08:36.831 [JavaFX Application Thread] DEBUG o.cryptomator.ui.fxapp.FxApplication - Main window initialized after 3113ms
Problem solved. Installation of new OS (Win10) solved the problem
