I have been using Cryptomator successfully for some time. Then I upgraded my Ubuntu to 18.04 LTS (what may or may not be an important factor here). Then I discovered Cryptomator is not able to launch.
I am getting an interesting stacktrace on the console. Any hint what goes wrong would be welcome.
The console output looks like this:
/usr/bin> ./cryptomator.sh
00:23:18.703 [main] INFO org.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.3.2 on Linux 4.15.0-30-generic (amd64)
00:23:18.758 [main] WARN org.cryptomator.launcher.InterProcessCommunicator - System property cryptomator.ipcPortPath not set.
00:23:18.763 [main] DEBUG org.cryptomator.launcher.InterProcessCommunicator - Could not connect to running process.
00:23:18.808 [main] ERROR org.cryptomator.launcher.Cryptomator - Failed to initiate inter-process communication.
java.nio.file.AccessDeniedException: .ipcPort.tmp
at sun.nio.fs.UnixException.translateToIOException(UnixException.java:84)
at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:102)
at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:107)
at sun.nio.fs.UnixFileSystemProvider.newByteChannel(UnixFileSystemProvider.java:214)
at java.nio.file.Files.newByteChannel(Files.java:361)
at java.nio.file.Files.newByteChannel(Files.java:407)
at org.cryptomator.launcher.InterProcessCommunicator$ServerCommunicator.writePort(InterProcessCommunicator.java:172)
at org.cryptomator.launcher.InterProcessCommunicator$ServerCommunicator.(InterProcessCommunicator.java:164)
at org.cryptomator.launcher.InterProcessCommunicator$ServerCommunicator.(InterProcessCommunicator.java:148)
at org.cryptomator.launcher.InterProcessCommunicator.start(InterProcessCommunicator.java:74)
at org.cryptomator.launcher.InterProcessCommunicator.start(InterProcessCommunicator.java:56)
at org.cryptomator.launcher.Cryptomator.main(Cryptomator.java:29)
